Sub box I've been thinking about...
Old May 9, 2002 | 10:22 PM
Scubaguy's Avatar
Has anyone put a sub box in the cubby to the right of your hatch? So that if you were to open the little locked door you would see the box? I have 1 10" sub and I was thinking of putting it in there. Do you think there would be enough room?
Any ideas are welcome
Mark
Old May 10, 2002 | 12:53 AM
Beene's Avatar
Well the only thing on the right side of my car in the back is the spare tire so I'll assume that you mean the left side. Anyways if you were to custom fiberglass the box I think that you could get a 10" sub in there. Just makee suree that you brace thee panel so It dosen't vibrate.
Old May 10, 2002 | 08:56 AM
deadtrend1's Avatar
i dunno about that .. its kinda small area. I keep my power cap, tools and jumper cables in there.
I guess with a little inginuinty it can be done.
~Tim
Old May 10, 2002 | 09:34 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
I put a triangle box that is sopose to go in the back of a truck back there. Hold on let me see if I can find a pic.
>if I dont post it I didn't find it
Old May 10, 2002 | 09:40 AM
Well I can find my pic, but here is someone else's pic they posted it here a while ago.
Old May 10, 2002 | 12:49 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
thats from my car!
Old May 10, 2002 | 04:04 PM
caleb's Avatar
Car: 89' Iroc
sub in spare tire area it can be done!
here is one that was made by:89blackGTA
Old May 13, 2002 | 09:42 PM
Scubaguy's Avatar
The reason I wanted to put my sub on the drivers side was so that I could retain the spare tire. I don't like the idea of running without it
My biggest problem (other than no time to build it) is I still need a small amp to power it. I olny need 100 watts total, any suggestions?
Mark
Old May 14, 2002 | 06:17 PM
THEISENATOR's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
Just buy a can of that fix-a-flat faom stuff for when your tire has a leak or gets flat in the middle of nowhere, of your tire blows, you probably should have repolaced it a while ago so it could have been prevented.
Old May 19, 2002 | 02:52 PM
BuddyLeeX's Avatar
Car: 06 Toyota Tundra SR5
it is possible to make a box that will fit in either. You coudl custom make a box taht would fit in the spare tire comparment much easier than a cubed box. It will look better and could possibly get it to sound better also. As for the small compartment on the left side, that would be more of a challenge cause you ahve to keep in mind the cubic inch measurements.
Old May 19, 2002 | 04:44 PM
GndPrx's Avatar
Yes it can and has been done, but the only way I would recomend it is if you are capable of building with fiberglass.
There is just about enough room in there to squeeze a 1cu ft enclosure if you glass in the whole area with an MDF baffle face. I would also recomend that if you are going to do run fiberglass up along the inside of the rear quarter that you place a layer of dynamat super or even a 1/8" foam rubber to give you cusion against the fender and the fiberglass.
This is actually in a 4th gen, but Mike (DJSexay) has done several versions of enclosures in these areas.
http://www.djsexay.com/imagegallery/...mage=amps1.jpg there is a link to his site...
Have fun, l8r
Amillionoh7
May 24, 2020 08:01 AM
midge54
Jan 29, 2017 07:00 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
