Dual vs Single
Old May 13, 2002 | 06:18 PM
BlueAlice91bird's Avatar
Dual vs Single
So I was looking at getting a new set of subs, and was wondering about the dual voice coil subs? How do they compare to a single. I mean would a dual be as good as a couple of singles. Would two duals be overkill?
Old May 13, 2002 | 06:54 PM
THE GTA's Avatar
GO with a Kicker substation. My buddy has an 8" in the hatch of his 90 camaro and it pounds hard than two 12's on a baffle board. For some reason and F-body is the ultimate enclose for one. Try it and you wont be disappointed.
Old May 13, 2002 | 08:19 PM
Supercharged84Z's Avatar
Car: 1984 Camaro Z28
Engine: 350 CID
Transmission: Beefed up 700R4
you can also wire up DVC subs to whatver impedence (usually people use 2, or 4 ohms) you want to .. i can wire my subs to 1 ohm if i want to. DVC subs are also more versatile than single voice coil subs.
Old May 13, 2002 | 10:03 PM
DRKTEALV6BRD's Avatar
hell yeah bro i have one 8" L5 solo baric kicker sub in my hatch in one of the kkicker substation black boxes and it pounds harder than 2 12s
Old May 15, 2002 | 10:01 AM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
No they're not. If you have DVC subs with 4 ohm voice coils than you have to either run them series (8ohms) or paralell (2ohms) if you have another sub you can run them paralell-series running VC's in series and subs in parallel giving you a 4 ohm total load. The only reason to choose DVC subs over SVC subs or the other way around is if you have to run your amp at a certin ohm load. For example if you had 4 ohm VC's you and need a 2 ohm load with one sub you should get DVC's if you need a 4 ohm load you need a SVC sub.
Sorry I havent been around latly ISP is down for a while (at school).
-Matt
Old May 15, 2002 | 10:35 AM
87transam5.7tpi's Avatar
-Matt
ya he;s right. pretty much if you have dual 4ohms you can do 2 or 8. and if you have dual 2 ohms you can do 4 or 1. they also make dual 6 and 8 ohms too.
Old May 17, 2002 | 06:44 AM
Ricer Raper's Avatar
Bull. There is no wayone 8 hits harder than two twelves and if the twelves are in a baffle board they suck. And if you compared the 8 to the 12 and the 8 hit harder than the 12's must suck.
Old May 17, 2002 | 09:57 AM
mudaholic's Avatar
i believe that was the point.. and please tell me.. why do 12s hit harder? because they're "bigger" ?
Old May 17, 2002 | 10:38 AM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
although Rice whatever went about it the wrong way, if you were to compair an 8 and a 12 of the same line (like two type-r's ), the 12 wouldnt necessarily hit harder, but hit lower. the larger cone area allows it to play lower frequencies. also, since the 12 does have a bigger cone area, it is pushing more air, so it could be hitting harder. but this is true when compairing equal subs. because there are deffinately some 10s that would give some of the 12s out there a run for their money....
Old May 28, 2002 | 05:02 PM
pennylessz28's Avatar
Car: www.hrfbody.com
Engine: www.hrfbody.com
DUAL
Old May 29, 2002 | 09:57 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Anything in a box will hit harder than 2 12s on a baffle board. As I've said hundreds of times, PLATES SUCK.
I put a 10" tube into a friend's Trans Am and it hit harder than my 4 12s on a baffle board. Sounded way better too. I have no doubts that a good 8" sub in a good box will outperform 2 12s on a plate. None at all.
LT1Formula
Oct 8, 2015 08:34 PM
zman1969
Oct 1, 2015 11:09 AM
