My amp is getting really hott!! Why??
Old May 26, 2002 | 09:29 PM
Camaro92RScalet's Avatar
Guys I am having a problem with my amp is getting real hot.
Does anyone know why this would happen??
Old May 26, 2002 | 09:50 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
you could have the speakers wired up wrong, but amps will run hot when pushed and it could be normal. most amps have a protection thing in them so if they get too hot, it will shut down before it hurts the amp. what do you have?
Old May 26, 2002 | 10:01 PM
Belker's Avatar
You gotta give us more info to get a meaningful answer.
Old May 26, 2002 | 11:58 PM
mcss383's Avatar
is it shutting itself off due to excessive heat? Or just hot to the touch? Some amps just run really hot....
Old May 27, 2002 | 08:26 PM
HrdRockA4305's Avatar
Most amps get hot, how hot is real hot? Also, do you have your speakers wired for too low of an impedence?
Old May 27, 2002 | 10:57 PM
SlowStangEater's Avatar
An amp is going to be hot. Usually too hot to touch. But its nothing to worry about
Old May 28, 2002 | 05:07 PM
pennylessz28's Avatar
Car: www.hrfbody.com
Engine: www.hrfbody.com
Maybe its not ventalated properly
Old May 29, 2002 | 01:45 PM
caleb's Avatar
Car: 89' Iroc
give more info, and im pretty sure you'll get more than a vague answer, include details, like what speakers your using, how their wired (series, parralell), specs of the amp, etc............
Old May 31, 2002 | 10:37 PM
The Chad's Avatar
Car: 84 berlinetta
Engine: lg4
Transmission: 700 r4
It could be because Stereo doesnt have a strong pre out like 2 or 4 volts. The less power the Stereo preouts are the more your amp has to work.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
