what gauge power wire?
Old May 29, 2002 | 12:58 PM
zee28's Avatar
Car: 86 iroc
I had a amplifirer in the car and used a 8 gauge wire.now I have bought a jbl amp(gts100 35x2rms)) and it has a plug/harness with only a 12 gauge power wire coming from it.I know I cant join the big and small gauge wires,can I?Do I just run a new 12 ga wire to the amp,and is that enough for it? Also this amp can be bridged and the other amp couldnt.It has a low/high or off position on the filter,do I turn this off if running it 35x2 and not bridged?thanks alot
Old May 29, 2002 | 01:28 PM
caleb's Avatar
Car: 89' Iroc
not sure on joining the wire, but fot the filter, that refers to what frequcnies that it filters out, if your running subs set it to low, that filters out everything except the low notes, if using it for a component set, set it to high it filters out everything but the high stuff, or if your using it on regular speakers for full range sound, then just leave it set to off
Old May 30, 2002 | 10:26 PM
Cuno's Avatar
get a fuse block with different gauge outputs. Most have 4 or 0 gauge in and then 0,4,8,12 gauge outputs.
BRoss99
Aug 10, 2025 05:08 PM
Jeremys87
Jul 14, 2022 09:08 PM
rocn7roc
Sep 21, 2021 02:16 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
