question about using CD-RW with Pioneer CD Player
Old Jun 9, 2002 | 11:17 PM
matthew's Avatar
Are most CD players compatible with CD-RW? I have a Pioneer DEH-7000R. It plays CD-R's, but i've never tried it with a CD-RW. The reason I want to use a CD-RW is because sometimes i download a song and I want to listen to it right away in my car, but I don't feel like burning a whole cd. Could i just put a couple songs on a CD-RW and then erase them later and add different songs? Would i still be able to play them in my car?
Old Jun 10, 2002 | 01:25 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Unfortunately, most decks wont play CD-RWs. You can always try it and find out. My Sony ES and my friends Pioneer Premiere wont.
Old Jun 10, 2002 | 10:08 AM
BAK12484's Avatar
sorry to say but it doesn't look like it will...
http://www.pioneerelectronics.com/Pi...29,130,00.html
however, all of their new DEH line supports CD-R and CD-RW - - not sure if you are looking to get a new deck, but that would be the way to go if you really wanted to play CD-RWs (I just ordered the 7400mp as a matter of fact)
Old Jun 10, 2002 | 12:02 PM
jawzforlife1's Avatar
my rockford mp3 deck does
Old Jun 15, 2002 | 04:00 AM
XxFreeBirdxX's Avatar
My Sony XPLOD head unit plays any cd..
Store-bought, CD-R, CD-RW..
If yours is newer, it should.. if not then that's just
Old Jun 22, 2002 | 10:02 PM
89RJcamaroRS's Avatar
Car: 1989 camaro RS
Engine: RAMJET 350
Transmission: RAPTOR 700-R4
i had a pioneer deh-p4100 that i used cd-rw's on and it worked fine. it just took 5 sec longer read the cd. but worked great
Old Jun 22, 2002 | 10:12 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
I got a Pioneer Premier DEH-P430 and when I use a CD-R Sometimes it will skip like NUTS like play for 5-10 secs then skip. And sometimes its Okay. Anyone help me out here?
thanks
Old Jun 22, 2002 | 11:13 PM
VampireHunterC's Avatar
The only bad thing that I have found with cd-rw is that you can only erase them and re-burn them twice, after that the songs don'y burn right and sound like they skip.
Old Jun 23, 2002 | 01:22 AM
deadtrend1's Avatar
thanks
Thats due to the media type of your CD's and the type of cd player you have. Darker media is always better to me, and I believe brands like HP, Verbatim, and Memorex (ceramic ones) to be ideal. The 50 cds for $2.00 dealies that come in just plastic wrap with names like kyhpermedia and HI-Val are crap. Its too light for the laser to see it, and hence skips like crazy.
Easy way to see, get a good dark cd and a POS CD-R and hold the bottom up to your eye. You'll notice how much easier you can see through the cheap ones.
As far as playing CD-RW's, you might catch a break and get a cd player that will play them. I wouldnt make it the primary foundation for buying the cd player though. They are much more expensive than plain cd-r's. Don't like the songs on the CD-R anymore, throw the cd away and burn again.
~Tim
Old Jun 23, 2002 | 03:01 AM
Ok... I have sony ones, and they skip. So your saying I should buy the black ones?
Old Jun 23, 2002 | 03:09 AM
I find that the Sony CDRs are very good. Now that 50 pack of HiVals I got, well they were free with the rebates and thats the only reason i got them. I must say that I was dissapointed with my new TDKs (they are now the silvers instead of the blues). What kind of burner are you using Mike?
Old Jun 23, 2002 | 09:55 AM
kid camaro's Avatar
Car: 91 z28
Engine: 305 tpi
i checked on the pioneer site to see if mine would play them. they cant find any info on it, its a deh-p8250.does anyone else have one of these? i got it in canada so maybe it was a canada only one.
Old Jun 23, 2002 | 10:58 AM
The best one's I have used are by MAXELL CD-r (and CR-RW). I bought tem to use on my home stero cd burner, but when i got my computer and didnt need to use the home stereo one I had all my left over cd's. So i troed them in the computer and they worked. The back of them are a deep blue color. I f the back of the cd looks like a reg cd (yellow) dont use it. If I lokks blue or green give it a try
Old Jun 23, 2002 | 02:47 PM
I'm using some cheaper burner I got from futureshop.
Here is the link.
http://www.futureshop.ca/catalog/pro...d=&newdeptid=1
But its the slower model they dont sell anymore; 8/4/40.
Old Jun 23, 2002 | 02:51 PM
How about these? People gave them good reviews.
http://www.futureshop.ca/catalog/Pro...7F#ViewReviews
Old Jun 23, 2002 | 04:05 PM
Well, I've never heard of the CD burner Mike. You might try a test: burn a CD at 1X speed and see if it plays any better in your car.
Old Jun 23, 2002 | 05:40 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
forget about using cd-rw's with some of the pioneer headunits, or most cd palyers for that matter. They dont seem to read the cd's probably because of the polymer that they use to make the data portion of the cd. I think the reflective foil layer is different too. I have never had any luck using cd-rw's with my poineer headunits. They refuse to read them. Some people seem to get them to work with the newer models but not me. The only thing that seems to like to play my cd-rws is my dvd player and my high end cd player.
Old Jun 23, 2002 | 06:31 PM
mudaholic's Avatar
nero burning rom seems to have better luck creating useable rws than adaptecs piece of crap.. true, a lot of things simply wont read rws no matter what, but if you have a good burner + good cds + good software, thats gonna be your best bet... my friend uses adaptec and i use nero, and all my cds play in both of our stuff, but his wont work on 4 or 5 different things.. same burner company, same package of cds..
Old Jun 23, 2002 | 08:52 PM
Nero is good because you can overburn discs.
Old Jun 23, 2002 | 08:53 PM
yeah i tryed at 1x...
Old Jun 24, 2002 | 02:37 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Dimented, you probably just need a newer Pioneer deck. For kicks, even though I'm not into that scene, I burned an MP3 disc onto an RW; it played fine on my Pioneer. My home rack system from '92 (Sony) is picky; sometimes it will play a burned CD fine, other times, it says no disc.
Old Jun 24, 2002 | 10:32 PM
Car: 88 Camaro SC
Engine: SFI'd 350
in the future i may get a newer one for my car. I put a fairly new one in my dads car for his b-day and i was surprised to find that it wouldnt play the rw's either. Im too buisy dumping money into my new engine so newer audio equipment has to take a back seat for now. But then again, the fact that cd-r's are cheap as dirt, i just use them and hell, if i get tired of the cd, i just toss it.
Old Jun 25, 2002 | 02:36 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
If it doesnt play it doesnt play. Not much you can do. Just get cd-Rs and write then at a slow speed or so. The only way to fix hard ware it to replace it with the goods.
Old Jul 3, 2002 | 12:25 PM
AZ28Freak's Avatar
I'm a burning CD Queen....
I find that the Diamond CDR's on ebay (100) for 24.95.....are very good. I burn tons of back up karaoke cd's which also have graphics, and work wonderful. Also, work great in any cd player so far. I also burn at the max 4 speed. May take a few minutes longer, but no skips, or problems.
Old Jul 3, 2002 | 07:54 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I was once a believer that "cheaper is better. How much diff can there be?"
I bought 50 CD-Rs for about $15. They're the Imagation ones. I thought they were fine. Then outta curiousity (with about 40 of the others left) I bought a set of 5 Sony "Music" CD-Rs for ~$7. I burnt the exact same songs onto one of them, then did a side-by-side comparison in my car. OMG!!!! The Sony's sound about 100 times better. Better SQ, imaging, stronger bass, more acurate bass, and I don't have to turn up my stereo as loud.
I'm not saying the Sony's are the best. But the more expensive ones ARE worth it.
As far as the CD-RW problem goes, I'm confused on one part of it. My HU (JVC KD-LX10) won't play them, but the stock Delcrap in my (now gone) '95 Monte Carlo would. Explain that?
AJ
kairles
Oct 26, 2015 09:13 PM
AilmentDiavolik
Interior Parts Wanted
Sep 9, 2015 02:17 AM
Ducati900ss
Sep 2, 2015 09:05 AM
zayne0
Aug 24, 2015 07:22 PM
redmaroz
Aug 16, 2015 11:40 PM
