component speaker help!!!
Old Jun 14, 2002 | 08:58 PM
Kandied91z's Avatar
i'm trying to install a premier component speaker setup.
on my woofer their are 4 contacts or prongs.......is there a reason for this? i'm only use to the simple 2 and don't want to mess up my speaker.
also, on the crossover......there is a seperate single + side for a -3db tweeter as well as the standard - and + for the tweeter that came with it........what is this for?
please help me out.....
Old Jun 14, 2002 | 10:07 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
the four prongs, you should check the manual that came with the speakers or look on their website for more info. the -3db is for an alternate way to wire the tweeter. if you feel the tweeter is too loud compaired to the midrange or one side seems louder than the other, you'd use this plug along with the regular tweeter -. just gives you some different options for install.
Old Jun 14, 2002 | 10:15 PM
Kandied91z's Avatar
well that's just it there isn't a manual or wiring diragram.
there are two single wires........each wire goes to a double prong setup on the woofer.
do i just pick one of each or what?
Old Jun 14, 2002 | 10:36 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Yep, just use one prong off each wire. Should be labeled + and -. The other prong can be use to easily hook up another speaker in parallel.
Old Jun 14, 2002 | 10:49 PM
Kandied91z's Avatar
that makes sense........
thanks for the help guys!!
Old Jun 17, 2002 | 08:45 AM
ATOMonkey's Avatar
The four prongs aren't because of dual voice coils are they?
Old Jun 17, 2002 | 08:09 PM
No, because there is only one pair of wires atached to the prongs. A DVC will have 4 wires.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
wanext
Oct 6, 2015 12:18 AM
Briandrex
Oct 5, 2015 06:20 AM
