where to ground amp???
Old Jun 15, 2002 | 12:45 PM
Kandied91z's Avatar
can i ground my amp to my battery since it's in the rear as well or do i have to ground it to the frame????
where is the best spot??
Old Jun 15, 2002 | 02:09 PM
bigt's Avatar
I would never ground it to the battery. Some piece of unfinished metal. I have my amp in the trunk of my convertible grounded to the same spot the trunk release motor is grounded. Easy to get to and didn't have to make a new hole.
Old Jun 15, 2002 | 02:16 PM
Tyler-88's Avatar
ground is ground.
i got two optima's in the back and the ground for the amps comes off the battery. mind you the battery is grounded to the frame
Old Jun 16, 2002 | 12:47 AM
coalyard's Avatar
Usually the chassis is best, a clean spot, and securely, so it doesn't vibrate loose. Other than that, anywhere where you don't get noise is best
Old Jun 16, 2002 | 01:31 AM
Kandied91z's Avatar
well i had a mind block and couldn't think looking for a quick fix........
i ended up just doing it the right way; just wasn't sure if it could actually hurt anything going straight to the battery.
thanks guys.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
