wiring alpine type r dvc to 360a2\\\\\\\??
Old Jun 16, 2002 | 01:04 AM
EjBaL's Avatar
Heres the deal. I got a rockford 360a2 amp, and I want to buy a 12" alpine type r dvc. Heres my question, how would I wire this to get the most out of the sub and the amp. I mean how would I wire the voice coils and everything. Please be specific. Thanks alot for any help you guys are great!
Old Jun 17, 2002 | 11:05 AM
EjBaL's Avatar
ttt sometimes I start to think that my posts are invisible.
Old Jun 17, 2002 | 02:04 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
No, but they just don't always seem to contain information that you can't get answered on your own by reading your owner's manual or manufacturer's websites.
Make sure you get a sub with dual 8 ohm coils and wire them in parallel (your sub's owners manual will show you how to parallel wire it). If you get the more common dual 4-ohm coils, you'll either wire it to a 2 ohm load that will eventually kill the amp, or you'll have to wire it in stereo and the amp won't make any power.
Old Jun 17, 2002 | 07:59 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I don't think that Alpine Type Rs come in dual 8 ohm coils. They come in 4 ohm and also come in dual 2 ohm coils. Get the 2 ohm coil version so that you can wire them in series to get 4 ohms.
Old Jun 17, 2002 | 08:11 PM
Jim85IROC's Avatar
Yup. I didn't realize they had a dual 2 but not a dual 8. Like Justin said, series-wire the two coils on each sub, and parallel-wire the two subs.
Old Jun 17, 2002 | 10:07 PM
EjBaL's Avatar
thanks alot
Old Jun 18, 2002 | 10:05 AM
microtek_10's Avatar
Car: 92 Z28
Engine: 355 tpi
I would have to say try to get ahold of the dual 2ohm's and wire it in parallel. A rockford amp should hold 1 ohm easy.
Old Jun 18, 2002 | 02:59 PM
EjBaL's Avatar
ok ate ikesound.com they dont have dual 2 ohm. So would I want to get single 4 ohm? I dont know anything about wiring dual ohm subs or anything like that, I know to hook up the positve and negative, and thats about it.
Old Jun 18, 2002 | 08:34 PM
EjBaL's Avatar
ttt
Old Jun 19, 2002 | 12:02 AM
RamAirZ's Avatar
Car: 1999 Camaro Z28
Engine: 5.7
ok, the Rockford amp and that sub would run best if you wire the 2 coils in parallel. Get a single dual 4ohm sub, wire in parallel to drop the ohm's to 2, this will allow the amp to pump more power to the sub allowing it to hit harder. The Rockford amp can handle a sustained 2ohm load easily.
Old Jun 19, 2002 | 02:35 PM
85maroz28's Avatar
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
This IS EJBAL ON MY BROTHERS NAME. So i shoud get a dual 4 ohm, and wire it down to 2 ohm, can u tell me exactly how to do that, and hook it up to the speaker terminal to plug the amp into?
Old Jun 20, 2002 | 04:37 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
We said that it says in the Subwoofer manual AND the amplifiers owners manual how to wire your subs! They have diagrams and everything!
Old Jun 20, 2002 | 10:12 PM
RamAirZ's Avatar
Engine: 5.7
You wire the positive from one coil to the positive on the other and run the wire from that coil to the amp and do the same for the negative. that will run it in parallel and bring the ohm's down
Old Jun 20, 2002 | 11:07 PM
EjBaL's Avatar
Thanks for the nice response ramairZ. To the other, I dont have the sub yet, I am checking into it before I buy it so I know what I am getting into, therefore I dont have the book. I know my fair share about car audio, like amps and all, but I just had a couple questions thats all. Other people ask alot stupied question that I do.
colton_carlson
Mar 8, 2019 12:21 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Cripley
Aug 17, 2015 03:35 PM
mx127
Aug 10, 2015 08:13 AM
