dual batt. or new alt...?
Old 07-16-2002, 07:11 PM
j166a99's Avatar
my system rocks, but when im in idle, my volt needle seems to want to bounce to the music too :lala: rrgggggggg!!!
so i need suggestions, buy a optima batt. or upgrade to a beefier alt. ? hmmmmm
Old 07-16-2002, 07:13 PM
mudaholic's Avatar
a more powerful alternator will actually produce less amperage at idle.. you might want to look into getting a dual-alternator setup..
Old 07-16-2002, 07:57 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Dual batteries will just place a bigger load on your alt, and thats not good if your already having problems. But just because your voltage drops at idle does not mean there is a problem. How bad is it?
Old 07-17-2002, 10:29 AM
BigMInstalls's Avatar
with dual batteries, and a power inline isolator, you'de be better off, at idle the stereo would draw it's amperage out of the second batterie...
Old 07-17-2002, 10:31 AM
heres a camaro I just did
Old 07-17-2002, 04:15 PM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
Transmission: Tire Chirpin A4
Okay, we all know when the bass hits it causes a large voltage drop right? So your already running one cap have you thought about separate caps for each amp? I'm sure you know what a cap does, and that would only make sense. Two 1.5 farads might cure your problem. I've never heard about a higher amp altenator being bad. I know this is a common factory practice if you have a lot of of power accessories.
Old 07-17-2002, 04:33 PM
mcss383's Avatar
Only if your alt isn't working properly.
12V < 14V. All current in a car with the engine running comes from the alternator unless the overall system voltage drops to 12V or below, then the battery helps.
Have you replaced the factory power/ground leads? If not, thats the FIRST thing you need to do. Put 4ga or so from the batt to the alt, battery ground, and batt to starter. Pull the alt and batt and have them tested. If the problem is still there (and very small, short time periods) try adding a capacitor. If the fluctuations are real big.....turn the volume down when you are sitting in traffic!!
Old 07-17-2002, 07:30 PM
Guest
Guest
Posts: n/a
hear is an idea i have seen any say yet. try to get a puller for the Alt. that is smaller then stock. when you do that it will make the alt spin faster at an idle. and that will mean more amps going out of the alt. on a stock setup the alt doesn't reallt put out the amp the car needs to run everything. not till you hit about 1,500 to 2,000 RPM. so i think the cheapest way would to get a new pully. you may need a new belt . all has to do with how small the new pully is.
Old 07-17-2002, 07:36 PM
camaro_60181's Avatar
Car: 1986 Iroc z28
I did the pully switch to but it didn't help that much
Old 07-17-2002, 07:59 PM
Guest
Guest
Posts: n/a
get a HP alt. then. about a 200amp one
Old 07-18-2002, 01:27 PM
miked's Avatar
Start with the alternator.
91 SrS
10-07-2015 04:32 PM
zman1969
10-01-2015 11:09 AM
Quick Reply: dual batt. or new alt...?
