need help with my new head unit
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
i bought a head unit from a kid at work...........works great, sounds great...only problem is that i need to know how to wire it in correctly.........i have it rigged right now..............
what happens is when i shut the car off the head unit does not retain its memory.....................
i am pretty sure i have all the speaker wires out of the head unit hooked up right, so thats not a problem
its a sony head unit going into a 1991 camaro
i have the wiring harness adapter out of the sony
AND i have the wiring harness adapter going into the camaro's harness
i bought it harness adapter at a car stereo shop and the kid who sold it to me told me just match color for color (on each harness)
it worked but i had to rig it, and no power is getting to the head unit when i turn the car off
its a sony CD head unit BTW
i have something wrong though, please help
thanx in advance
thanx in advance
nope didnt work.....................
also, the only way the head unit will work is if i connect all 4 power wires all together
yellow+red+yellow+red
what am i doing wrong here?
bad ground maybe?
so instead of yellow+yellow
and red+red
i have yellow+red+yellow+red...........thats the only way it will work
bad ground maybe?
and red+red
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Your constant hot must not be working, thats why it comes on with all 4 connected together, and the key on, otherwise it would stay on if the constant hot is the working one, check your fuses if not go chasing your wires, maybe run a new constant hot.
ambainb
Apr 25, 2016 09:21 PM
