need help from custom box builders
Old Aug 13, 2002 | 01:32 PM
pronger44's Avatar
how do you hide the screws and still make each board of the box individualy wrapped with carpet?
Old Aug 13, 2002 | 01:39 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
Why would you want to individually wrap each board?
Old Aug 13, 2002 | 02:11 PM
ATOMonkey's Avatar
Cut out a small round piece of carpet and glue it on top of the screw. You can do the same thing to wood if you counter sink your screws to make the surface flat.
Old Aug 13, 2002 | 02:44 PM
Soulrev's Avatar
Car: Formerly - 87 T/A, 87 Bird.
Why would you want to go to the bathroom? Why would you want to breath air? He wants to know how to do it, who cares "why" Lol just messin with ya.
Old Aug 13, 2002 | 03:50 PM
mudaholic's Avatar
well it doesnt really make much sense to do that... one option would be to just glue covered boards to the outside of your box, i don't really see any other way to do it...
Old Aug 13, 2002 | 06:11 PM
pronger44's Avatar
i don't think you understood me. all the boxes you see that aren't homemade have the screws hidden, but at the same time the box isn't wrapped in one giant piece of carpet. maybe not every side and piece of the box is wrapped but theres more than one piece. does this make anymore sense?
Old Aug 13, 2002 | 06:17 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
If you look at most of the pre-fab boxes, they have sunken sides to them. The piece that's sunk in doesn't have any screws on the face of it. Every other side is screwed into that piece. Does that make sense? So basically most boxes have 3 pices of carpet. One wraps around the box. The other 2 pieces go on the sunken ends.
Old Aug 14, 2002 | 09:04 AM
ATOMonkey's Avatar
If you glued it and used finishing nails/brads then they wouldn't show up either.
Old Aug 14, 2002 | 11:55 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If you know how to put the carpet down you can make it seamless. When I build square & wedge boxes, I wrap the box in 1 piece of carpet. I seam it on the bottom and seam it in a certain pattern on the side. If you cut the carpet straight & accurately, and push it together when you glue it down, the seam will not be visible.
Old Aug 14, 2002 | 07:14 PM
CaysE's Avatar
i have another question: when the specs on a sub say it needs a certain volume of air in a sealed enclosure, can I just put it in a box with that volume in it, or do I have to take into account the basket on the sub?
Old Aug 14, 2002 | 07:58 PM
mudaholic's Avatar
depends on the manufacturer. with infinity, you just make the box that large; i cant say for sure with any other manufacturer
Old Aug 15, 2002 | 09:49 AM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
Almost always you have to take the recommended volume and add the driver displacement to get the total air volume required. That's why the spec sheets have that info.
Old Aug 15, 2002 | 05:02 PM
CaysE's Avatar
OK, I looked up the specs on the Infinity Kappa 120.3se and it says it needs exactly one cubic foot of volume in the box. I only have a vague idea of what most of the measurements in the pdf represent, and I'm pretty sure none of them are driver displacement. So am I good at 1 ft^3 ?
Old Aug 15, 2002 | 05:08 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
With that particular subwoofer, the volume includes the driver displacement. So it's 1 cu.ft. total.
HP52TA
Feb 3, 2018 10:51 PM
bubbaz28
Sep 18, 2015 02:09 PM
Deemax
Sep 12, 2015 06:53 PM
Ranbo108
Sep 9, 2015 12:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
