JL audio 6" subs in kick panels enclosures?
Old Sep 10, 2002 | 03:07 PM
brian89transam's Avatar
Will JL 6" subs fit in those kick enclosures at fbodyaudio? I think the sub is actually 6 1/2". Not sure on the top mount depth though.
Old Sep 10, 2002 | 07:04 PM
CrazyHawaiian's Avatar
Car: too many ...
No they wont fit. The kickpanels are made for 5 and 1/4" seperates. The 6.5" speaker is actually a midrange bass speaker, not a sub. The 6.5" set should also come with a tweeter (its a component set for midrange and high's). If you want to use the 6.5's (they are excellent for midrange), you can do what I'm doing. I found a bracket to convert the 6x9 opening to accept the 6.5" misbass driver. Then you just need to custom mount the tweeter. Combine that with a seperate setup in the front (5 and 1/4's in a kickpanel like you asked about in the other post), and some subs in the back (2 10's or 12's) and you'll have a very nice sounding setup.
Old Sep 11, 2002 | 02:49 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
They'll fit in the kicks, but they would need to be closed to create an enclosure. The depth is a little more than I would reccomend for the kicks too. It could work though. If you look at the JL Audio website they call their 6" W0 "a true subwoofer". It would be cool, but the custom stuff to make it work would drive up the price a little.
Old Sep 12, 2002 | 04:08 AM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
like say how much?
Old Sep 12, 2002 | 07:32 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You're either going to have to find a new place to put your feet or you're going to have to chop up the metal panels behind the kick panels to get enough airspace for those subs to work worth a damn. Then after all that work, you're still going to have a severely limited bandwidth due to the physical limitations of the small driver. Those work nice running a pass-band of 50-80hz, or even 50-200 since they'll be up front, but you would still need a sub for the 50-down range. Because of that, all you wind up doing is complicating the soundstage with additional drivers. Running a pair of 6.5" components with the bass driver running 60+ or 80+ will probably result in better sound and less headaches.
Old Sep 12, 2002 | 09:37 AM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
With only .15 cu.ft. of airspace required, I don't think it would be much of a problem. Jim's right about the narrow bandwidth operation though. They don't like to reproduce sound below about 60-70 hz and they peak at 100-120, in most enclosures. To me that's just annoying. Again, it probably could be done. I'm guessing the price would be around $250-$270 for a set.
Old Sep 12, 2002 | 04:21 PM
Car: too many ...
Wow cool, didnt know JL made a true 6" sub. I thought the smallest subs they made were the 8" microsubs with the enclosure included. Learn something new every day!
Old Sep 13, 2002 | 09:10 AM
miked's Avatar
There are some good midbass speakers out there that have alot less mounting depth and would provide the midbass you may be looking for. Orion had a 6MB and an 8MB and I know kicker has the same sort of deal going. I have a 6.5 inch midbass in my door with a 4 inch component set in the kicks. I'm happy with it. I keep wanting to try a 8MB in the door and a 5.25 component set in the kicks. I don't know if it would be that much better to warrant building new door panels though. Anyway something like this might be easier to manage than that JL sub from what I'm gathering.
91 SrS
Oct 7, 2015 04:32 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
raymondandretti
Sep 27, 2015 06:43 PM
tattmann
Sep 27, 2015 05:20 PM
efiguy
Sep 27, 2015 01:30 PM
