Would wiring a head unit cause an ignition coil to die?
Old Sep 24, 2002 | 09:40 AM
PimpRod92RS's Avatar
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
Hey guys,
I just bought a Sony 850 X head unit (the one w/ the remotes) and I rigged it up real quick to see if it would work, and sure enough it did, but where it gets hazy is when I go to start my car in the morning and the ignition coil is dead. Did messing with the wiring of the car cause a surge in the coil and cause it to die, or is this just coincidental? I find it really weird that this happened while my car is a mess.
Old Sep 24, 2002 | 11:28 AM
deadtrend1's Avatar
coincidental. The HU is on a different circuit than the ignition coil.
Old Sep 24, 2002 | 01:46 PM
Hmm, thanks thats what I thought, was just seein if it had anything to do with it, just incase. Guess I'll just replace the coil and be back on the road.
Old Sep 24, 2002 | 02:13 PM
CrazyHawaiian's Avatar
Car: too many ...
If you wired it properly then it shouldnt be related. double check the wiring to make sure. what kind of coil was it?
Old Sep 26, 2002 | 07:16 AM
Yeah I just figured it out, the coil was good, the ICM was bad, I swapped in a new one and there u go, problem solved. I guess it was just a coincidence that it died the night I was tinkering w/ my head unit.
92camaroJoe
Jul 29, 2023 07:57 PM
apo_bailon15
Mar 28, 2016 05:20 AM
92camaroJoe
Aug 13, 2015 06:07 AM
ZsTransAm
Aug 11, 2015 07:30 PM
92projectcamaro
Aug 6, 2015 01:20 PM
