can you help me with this angle?
Old Oct 7, 2002 | 10:52 AM
White Ninja's Avatar
does anyone know this angle measurement off the top of their heads or do you know of anyway i can measure it?
i suppose the measure on both sides is the same...
work with me on the drawing.. it took 2 seconds, it's if you cut the bumper and stuff off the back of the car and looked at it directly from the back
Old Oct 7, 2002 | 11:12 AM
BadMunky87TA's Avatar
take 2 peices of wood and form them to that angle then break out the protractor(compass,ruler dunno its been awhile)
im guessing this is for builting a box? if that is the case then you could just bypass that angle completely and do the 90* thing
Old Oct 7, 2002 | 12:26 PM
Ragnarok_Tyr's Avatar
I agree with BadMunky about using a 90-degree angle for that part of your (presumed) box. The amount of airspace you would lose is insignificant, and it leaves a lot less room for error in measuring the distances necessary to make it. Nothing sucks worse than fabricating pieces and finding out they don't fit. Otherwise, just use your trig functions on a calculator (But as mentioned before, make sure your measurements are accurate.)
Old Oct 7, 2002 | 04:22 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I 3rd the motion. 90* is hard to screw up. If you make it some arbitrary angle like say 85*, you've got some major work to do when cutting the top and bottom sections, plus you've got to use sin equations to determine distances. Granted none of that stuff is going to cause the world to stop turning on its axis, but for the absolutely minimal gains, it just isn't worth the hassle.
My first couple boxes incorporated some funky angles for the section that goes foward toward the back seat. I learned very quickly that whenever you can avoid complex angles, you're better off.
Old Oct 7, 2002 | 04:51 PM
you're right... it's really not worth the gains i guess.
jbates346
Oct 21, 2015 01:50 PM
mfp189
Sep 27, 2015 09:25 AM
Linson
Sep 21, 2015 01:08 PM
FED 387
Sep 16, 2015 12:18 PM
Night rider327
Sep 16, 2015 02:20 AM
