Will not play burnt CD's
Old Oct 14, 2002 | 12:34 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Hey I have an older Alpine CD player and it will play some CD's that other people have burnt but the ones I burn it will not play. Is there anything I can do to get thing thing working?
Brian Felts
Old Oct 14, 2002 | 12:52 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Just make sure the CDs are nice and clean...other than that, I think if it doesn't play them it just doesn't play them.
Greetings from not-so-far-away (near Dayton).
Old Oct 14, 2002 | 01:04 PM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
make sure u are not using cd-R's. i dont figure u are but just in case make sure. the particular brand u r using just may not work with ur deck unit.
good luck,
jacob
Old Oct 14, 2002 | 01:14 PM
I am using Memorex CDr does this have an effect on my problem? I would like it to be that easy!!! If so what kind can I use?
Brian
Old Oct 14, 2002 | 01:31 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Some older cd playerz will not play cd-Rs and cd-RWs You could get a chip or something sodered into the stereo board but that would be a real PITA and easier to buy another stereo. I didnt pay attention but was it a cd-R or a cd-RW.
Old Oct 14, 2002 | 02:22 PM
MuttandJeff's Avatar
Engine: 5.0 TBI
Transmission: 700R4 Auto
Try Imation CD-R's. I use them in my 98 S-10's stock radio and they play just fine they also play in my walkman. If you want an alternate brand, pick one with a silver finish on the burning side. Sometimes standard cd players will not play CD-R's with a colored surface (green, blue, etc.)
Old Oct 14, 2002 | 07:42 PM
ninety1TAgta's Avatar
I believe what allows your head unit to read CD-R and CD-RW and scratched CDs without skipping is a strong laser. So try a different brand, it could be your brand writes it a bit weaker? Also it could be your burner writing it weaker... The stronger the laser the crappier CDs/more your head unit can read.
greg
Old Oct 15, 2002 | 10:15 AM
FyreLance's Avatar
Yes, :hail: Imation CD-Rs.
Old Oct 15, 2002 | 12:26 PM
FyreLance's Avatar
good luck,
jacob
You mean CD-RW's I think
Old Oct 16, 2002 | 11:08 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I have a walkman that's about 14 years old. It plays cd-r's. If the cd is not finalized it will sometimes have trouble. Are you finalizing your cd's?
I use verbatim cd's.
How's this for screwed up. My 14 year old walkman plays cd-r's but my x-box does not.
Old Oct 16, 2002 | 11:32 AM
FyreLance's Avatar
:sillylol:
Did someone say Sony superiority over Microsoft...?
Old Oct 16, 2002 | 01:22 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
yup. go figure.
Old Oct 16, 2002 | 03:53 PM
spike1856's Avatar
Car: '86 SC
Engine: '88 2.8L
I didn't tell you this (), because apparently Microsoft hasn't attempted to publicize it (and therefore must want it to be shushed), but I seem to recall reading something back when the X-Box was first released that said it can read CD-RW's, but not CD-R's. So, you might want to give it a shot
Old Oct 16, 2002 | 07:18 PM
paul russell's Avatar
Car: 86 trans am
Engine: 5.0 tpi gtauto ramair and notch
Transmission: 700 r4
i also had trouble like that with my g.f.'s cd player i burned them at a slower speed and they play everytime no matter what brand i use. but i been using the comp usa plain silver cd's so nothing shows threw the label
Old Oct 16, 2002 | 08:52 PM
tonkaman3's Avatar
Car: 1985 Sport Coupe
Engine: 2.8L
I also agree with viprkilr, in that your burned cd's need to have been "closed" after they were completed. I had the same troubles with my in-car player until I figured out what was going on. Silly me, I thought it was an automatic function when the disc was done recording
Old Oct 16, 2002 | 08:59 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Will not play burnt CD's
Brian Felts
color color color.
some players dont like certain colors of the dye used on the blank cdr's.
Ive heard that the black ones they make for style [really to burn pirate play staion games] will not work in 99.8% of all cds players even new ones.
Old Oct 16, 2002 | 09:15 PM
spike1856's Avatar
Car: '86 SC
Engine: '88 2.8L
Re: Re: Will not play burnt CD's
Originally posted by Gumby
color color color.
Actually, black CD-R's are much more difficult to scratch badly enough to damage them. Take a bit of sandpaper to one, and see if it still plays. It'll skip a bit, of course, but not nearly as bad as a normal cd or cd-r would. I do believe that was why Sony decided to go with them for the Playstation in the first place. (By the way, you don't have to use black cd-r's to burn playstation games...)
Old Oct 16, 2002 | 11:35 PM
Tell you what, go to a stereo shop and try the cd there at the store. If it works buy that cd player.
Old Oct 17, 2002 | 10:42 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I think I will. Thanks!
antman89iroc
36
Jan 31, 2016 08:42 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
rusty vango
Sep 29, 2015 02:44 PM
Bigold4x4
Sep 28, 2015 05:21 PM
