running power wire
Old Oct 28, 2002 | 08:50 PM
burnouts4ever's Avatar
running power wire
wheres a good place to run 4 gauge power wire in our vehicles, where have you guys ran ur power wire and rca's?
Old Oct 28, 2002 | 11:08 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Power = Drivers Side.
RCA's = Passenger Side.
Works everytime...
Old Nov 2, 2002 | 11:48 AM
CaysE's Avatar
You might want to switch sides, depending on where your battery is. Some batteries are on the passenger side, in which case you want the power through the passenger side, as well. If you take the door sill trim off of each side, you can find some power wires already running though one side. These go to the brake lights in the back. Run your 4-gauge through the side that has these wires, put the RCAs through the opposite side, and you're set.
Another option for RCAs, which I've done, is run them through the middle console and under the carpet. It allows for shorter RCA cables, hence cleaner signal.
BRoss99
Aug 10, 2025 05:08 PM
midge54
Dec 27, 2019 04:14 PM
Caspar
Jun 19, 2016 11:19 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZsTransAm
Aug 11, 2015 07:30 PM
