New cd player turns off for no reason.
Old Oct 31, 2002 | 02:28 PM
camaroracer1's Avatar
Car: 1988 Iroc-Z
Engine: 5.7 TPI
Transmission: TH-350
Axle/Gears: 12bolt/4:10
Hey guys,
I just bought a Pioneer Deh-1400 cd player and when I'm driving around the system all of sudden shut off and then comes backs on. It does this when playing cd's or when listening to the radio. I checked all of the wire connections and they are all fine. I noticed that most of the time when I am taking turns or driving over bumps this problem happens.
Old Nov 2, 2002 | 11:29 AM
CaysE's Avatar
Are you certain your wires are ok? To me, it sounds like a shorting problem. If your connections are good, maybe you have a torn wire somewhere. Worst case scenario is something it loose inside the headunit. Bring it back to the store you got it from and have them replace it. If you're really stuck (no receipt, no returns, etc), bring it to a car audio shop and have them test it out. If something's screwed up inside, they can fix it.
Old Nov 5, 2002 | 10:22 PM
otterball21's Avatar
check your speakers
I had this kind of problem before when I drove my truck. I would drive hit a bump and the headunit would completely go out. Aftermarkets are built with an automatic shutoff if it shorts. I replaced my speakers and I found one of my speakers were shorting. I had installed low hz blockers and they were grounding with the wall. good luck!
Old Nov 5, 2002 | 10:28 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Yup that sounds like the good old Bump and Ground.
Check all the connections, somting is loose.
Old Nov 6, 2002 | 02:21 AM
9OFirebirdV6's Avatar
If its got a detatchable face, check to make sure its not loose.
Old Nov 6, 2002 | 01:53 PM
Car: 1988 Iroc-Z
Engine: 5.7 TPI
I found out what the problem was, the accesory wire was shorting out someplace. I couldn't find the short in the wires, so I wired the accesory wire from the head unit to a 12volt source in the fuse boxes only when the ignition is on. I have been driving around for a few days now and it doesn't shut off anymore. Thanks for the info.
Old Nov 6, 2002 | 01:57 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Told Ya....
Glad we could be of assitance...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
FormulasOnly
Sep 10, 2015 09:07 PM
