i need help with an amp!!!!!
Old Nov 6, 2002 | 07:48 PM
RIcamaroguy's Avatar
hi i just got a precision power a404 amp off a friend and i was curious as to how to hook it up... i just want to run a set of 6x9's off it.. or possibly my 4x6 and my 6x9's what do i need for hard ware... hope you guys can help
Old Nov 7, 2002 | 04:04 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
First off, you need to make sure that your head unit has the necessary connections (RCA pre-out jacks & amp acc wire)
If your head unit has these connections, just run the wires to the amp. Then run a power and ground wire and you are set.
Old Nov 7, 2002 | 07:12 AM
fly351's Avatar
Car: 1996 Camaro RS
Engine: v6
remote wires are also very nice to have. It should be the Blue wire on the back of your deck (if it has one) it should say "remote" on it. just run it to your amp to the "remote" connection (once again, if the amp has one, which it should). this will turn your amp on and off when you turn your deck on and off.
-fly
Old Nov 12, 2002 | 08:20 PM
SlowMaro's Avatar
make sure your ground wire is 3 feet long or LESS, any longer and you could potentially fry the amp
Old Nov 12, 2002 | 08:37 PM
KicKeR's Avatar
Make sure you have the proper equiptment yes, and make sure your wire ( such as power and ground ) are thick enough to properly serve the power your producing.
Old Nov 17, 2002 | 01:41 PM
Huckster's '84 TA's Avatar
Car: 1984 Pontiac Trans Am
Engine: 5.0L
Transmission: TH700-R4
i dont know much about that amp, but i believe is has some power to it so if you hook it up to you speakers, be sure you dont have the gains to high or you will blow them, especially if you decide to run the 4x6's of of it. those speakers are fairly efficient, so they dont usually need that much power to be loud.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
