Darn ignition. Messed up my sterio!!! What now?
Old Nov 9, 2002 | 09:47 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Ahh it sound GREAT when the car is OFF but when i turn it on...
NOISE! Scratchy crap! I can hear every darn spark through my speakers. I guess it cause of my MSD 6BTM etc etc....
What can I do about it??
Old Nov 9, 2002 | 01:25 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
I tried regrounding it and no luck! help! I think its from my plug wires?
Old Nov 9, 2002 | 01:31 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
And I want to point Out i DID do a search and found alot about grounds etc...
It only makes noise with the radio on, and only while the car is running. the noise does not change with RPM. Its just interference with my Radio signal...
I can play CD's all day long with no interference so its nothing to do with the speaker wires coming from the radio.
Radio and speakers are all brand new. Just put it all in yesterday.. Car never had a sterio Since ive owned it so I dont know if the old one did the same thing or not...
Thanks... Im thinking maybe I should upgrade the plugwires?
ANyone here have a MSD ignition box and have this problem?
Could it be my antenna? its pretty bent up, but works perfctly fine when the car is off...
Old Nov 9, 2002 | 01:48 PM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
Well if it's only doing it with the radio, you might want to check that your antenna wire is ok. And if it was the plug wires, you would think it would change with the RPMs.
Old Nov 12, 2002 | 02:53 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
<b>Well if it's only doing it with the radio, you might want to check that your antenna wire is ok. And if it was the plug wires, you would think it would change with the RPMs.
</b>
Well consider it only does it when the cars running. if it was the antenna wouldnt it ALWAYS have crap reception?
Old Nov 12, 2002 | 08:08 PM
SlowMaro's Avatar
i say check the ground to the actual stereo itself.....
Old Nov 12, 2002 | 10:46 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
<b>i say check the ground to the actual stereo itself.....</b>
I have it going directly to the battery... is that bad?
somone said to ground it to the chassis instead... I dont see a difference but maybe I should try that...
Old Nov 13, 2002 | 03:28 AM
bunghole's Avatar
supposedly the same but not
It should be the same, but everytime I have grounded to the battery it has always backfired on me somehow. Try to actually ground it to the chassis it should help a lot
Old Nov 14, 2002 | 01:09 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
will try it tommarow.. thanks!
F-body-fan
Jan 12, 2023 01:49 PM
Ed1LE
Sep 30, 2018 09:14 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
mrbird
Oct 20, 2015 03:43 AM
