Im audio "dumb dumb" but learning!
Old Nov 23, 2002 | 09:30 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
what should I set the HPF and LPF to... I have no idea if I am suppose to set these to make better sound or what? Im running Infinity Reference speakers back and soon to be front if that makes a differnce...
thanks
Old Nov 23, 2002 | 11:25 PM
9177's Avatar
LPF=low pass filter meaning all frequencies above your setting will be filtered out this is used on subs.
HPF=highpassfilter and filters all sound above your setting and is used for mids and tweets
I would set the dash speakers at 125htz whith the HPF on and only use a HPF on the rear speakers if you don't have a sub.
Old Nov 24, 2002 | 12:11 PM
WOW! I had the HPF set to off and my rear speakers would always sound like there was a bunch of distortion....and then I set the HPF to 125mhz and it cleared them up......
why is that? I also set the LOUD to ON....
Old Nov 24, 2002 | 12:39 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
LPF = Low Pass Filter = All below these Hz is played. Anything above is cut out.
HPF = Hi Pass Filter = All above this is played. Cuts out all Hz below.
Cleared up your 6x9's, cause they aren't playing the super low stuff (they shouldn't anyway)
Old Nov 24, 2002 | 03:42 PM
9177's Avatar
I would also shut off the loudness feature. That usually adds distortion to the system.
Rocket-Doc
Nov 14, 2015 02:08 PM
Nick Locking
Car Audio
Sep 30, 2015 04:24 PM
drumstixer
Sep 29, 2015 03:02 PM
mfp189
Sep 27, 2015 09:25 AM
Rally Smith
Sep 14, 2015 06:59 PM
