When bumping, severe rattling heard from outside
Old Nov 29, 2002 | 08:59 PM
dunerida82's Avatar
Car: 1991 RS
Engine: 305 TBI
I have a Kicker Solo L7. When I bump, it sounds beautiful inside, but from the outside, the whole cabin is rattling and sounds like pure crap. The license plate rattles and the F-body towards the rear rattles. Im not sure that dynomatting would even help in an open 3rd gen cabin. Any one had this problem?
Old Nov 30, 2002 | 11:17 AM
1982chevycamaroz28's Avatar
yea when im playing my system my plate rattles so what i did as a temperoy solution i put a small rag behind it works good
Old Nov 30, 2002 | 05:59 PM
KsKid's Avatar
i fixed alot of my problems just by tightening stuff up, it seems like stuff comes loose as it gets older. other than that i've also found that the soft side of velcro is a nice way to keep things from touching (thus rattling) just get some of it with one sticky side and voila! ohya, a thick coat of rubberized undercoating spray helps too, but that doesnt really ever need to be used.
Old Dec 1, 2002 | 12:13 PM
MdFormula350's Avatar
i can vouch for that, stuff does lossen over time, i try and tighten stuff up once a month..
Old Dec 1, 2002 | 12:50 PM
FLYNLOW92rs's Avatar
Some dynomax on the body on the car on the inside wouldn't hurt.....
What exactly is shakin all around...
velcro on the license plate works too...........
Old Dec 2, 2002 | 01:20 PM
CreatiVe2's Avatar
doors....
i have the same problem.. its my doors that are ALWAYS rattling.... but if i roll (yes roll) my windows down a quarter of an inch the rattles stop.. any clues to whats up?!
Old Dec 2, 2002 | 02:24 PM
KsKid's Avatar
do you have t tops? where from the door is the rattle coming from?
Old Dec 2, 2002 | 05:13 PM
CreatiVe2's Avatar
inside the door... and when i shut the door it sounds like just metal hitting metal.. ithink its the window....
Old Dec 2, 2002 | 06:27 PM
KsKid's Avatar
heh time to rip the door apart and tear out the sticky velcro! thats all i do whenever i have a rattle
Old Dec 2, 2002 | 11:42 PM
CreatiVe2's Avatar
yeah i have taken the door apart... i just dont know where the actual rattles are....
Old Dec 2, 2002 | 11:50 PM
KsKid's Avatar
now that the door is ripped apart close it and blast the subs again... the rattle should be very loud now that its in the open, if nothing rattles then it has to be something that you took off
Old Dec 3, 2002 | 09:53 AM
CreatiVe2's Avatar
Ahhhh good idea =-) and what do you recomend that i put to dampen??
Old Dec 3, 2002 | 05:02 PM
KsKid's Avatar
ummm just stick something between the 2 things that are rattling, make sure it will stay there though or the problem will come back. duct tape works pretty well. also check the vents inside the door jam, they arent on the door but on the body instead. if you have 6X9's hitting hard then it forces air out them the wrong way and that rattles alot. just take it off then take the back of the vent off and remove the rubber... gasket type thing. then replace and thats finished, while the tools are out you should probalby do that anyway because any amount of bass from the 6X9's will make those rattle. good luck
Old Dec 3, 2002 | 05:25 PM
dunerida82's Avatar
Car: 1991 RS
Engine: 305 TBI
This is an obvious find, but sometimes your deck mounting kit (plastic usually) can slip, and rattle to the base too. I had to get it remounted.
Old Dec 3, 2002 | 11:48 PM
CreatiVe2's Avatar
yeah i did the 6x9 thing a while ago... but its still the doors that rattle.....
Dune what do you mean by deck mounting kit?
Old Dec 4, 2002 | 07:29 AM
KsKid's Avatar
i think he means the plastic trim under the door... i sorta had a problem with that bu ti'm still not sure what he meant
Old Dec 4, 2002 | 08:45 AM
CreatiVe2's Avatar
yeah hum... im thinking that that might be the problem.... can you explain more?
Old Dec 4, 2002 | 06:35 PM
dunerida82's Avatar
Car: 1991 RS
Engine: 305 TBI
I mean for your deck. Your stock stereo is pulled, then your new one is there, but as you know, new stereos are skinnier. They require that plastic mounting kit. That mounting kit, right in the front, I found was rattling. I turned my head, to see where it was comin from. When I placed my finger on it, it stopped. It is basically the kit that is holding your deck in place. The surrounding plastic basically was rattling.
Old Dec 4, 2002 | 07:50 PM
CreatiVe2's Avatar
i know its not that..... because theres no sound coming from my head unit.. =-\ only doors...
Old Dec 5, 2002 | 09:10 PM
Firebird SE 84's Avatar
I had the problem of stuff rattling on my saturn (the body is plastic so alot of stuff rattles) mount stuff in sheet ruber like they use for truck bed mats and smooth 1/4 inch works good also just use liquid nals and put it straight on the back of the licence plate and it wont sound like a banjo any more i dont know if it better on an f-body (steel body) because my firebird is gutted inside its becoming a drag car, but im buying another f body probaly an IROC Camaro that im keeping road legal in this spring because i need to build credit because i paid cash for my firebird, and my parents bought my saturn back in may for my 16 birthday
c-ya
Old Dec 5, 2002 | 11:09 PM
CreatiVe2's Avatar
license plate?
Old Dec 13, 2002 | 07:01 PM
caraudioaddict's Avatar
I've had the problem with the 6X9 rattles, I fixed that by going to aftermarket boxes (also sounds better because you can Aim them)
The License plat rattles can be fixed by putting two more bolts along the bottom of the plate
The only rattle I can't get rid of is from underneath the car. Can't even find what is rattling, but it is under the car.
Old Dec 13, 2002 | 10:58 PM
CreatiVe2's Avatar
Thas a paint in the ***... ever try to look at the actual mufflers... or the seat pans....
Old Dec 14, 2002 | 11:59 AM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
answers
first of all to stop most of the rattling i ripped up the rear carpet and laid down just basic foam then pull the door panels off and wrap thin foam around the rods for the lock and inside handle when the bass hits those rods hit the door metal. come on did it really take a 17 year old to figure this out!
Old Dec 15, 2002 | 01:21 AM
CreatiVe2's Avatar
hahah thats a good idea....
Old Dec 23, 2002 | 03:47 AM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
after your exhuast is cool check the muffler heat sheild it maybe loose it is on mine and sounds like CRAPPOLA
Old Dec 26, 2002 | 12:40 AM
dunerida82's Avatar
Car: 1991 RS
Engine: 305 TBI
Guys, I was driving the other day, and did something incredibly simple that made a world of difference. I was playin that new 8mile CD, and I noticed a rattling from the inside. I know I was concerned about the exterior racket, but this is strictly inside. It was coming from the passenger door. It was the plastic cover thing that runs at the top of the passenger door, right below the window. You hold that with your finger, and the rattling stops. I just need to find a way to keep it that way. Its the plastic top part that runs the full length of the door, right below bottom part of the window.
Old Dec 26, 2002 | 05:02 PM
CreatiVe2's Avatar
full length how so... from front of door to back of door....
Old Dec 27, 2002 | 11:38 PM
dunerida82's Avatar
Car: 1991 RS
Engine: 305 TBI
Creative
From the hinge of the door, to where a doorlock stem would be (on most cars).
Old Dec 28, 2002 | 12:05 AM
CreatiVe2's Avatar
thats what i though b/c thats what i think the problem in mine is too... how woul di go about checking it.. and how do i know what part it is...
Old Dec 28, 2002 | 12:20 PM
dunerida82's Avatar
Car: 1991 RS
Engine: 305 TBI
I havent found a real solution, but check it buy simply turning the subs or stereo up, pinpoint where the rattling is, and press your finger against possible spots. I havent found a way to fix it, but I'm working on it. Find the problem first. Use them ears.
Old Dec 28, 2002 | 01:05 PM
CreatiVe2's Avatar
ahhh i have to try that... tell me what you find...
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
HoosierinWA
Oct 7, 2015 10:15 AM
1HotZ28&SS
Sep 28, 2015 08:58 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
