Always Somethin!
Old Dec 2, 2002 | 10:18 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Always Somethin!
Well, in the past few weeks I have replaced all my factory stereo crap and put in a Sony CDX-M730 cd player, Infinity Reference 6953i 6x9's in the rear, Infinity Reference 4652cfp's in the dash, all for $275.00 the only thing used are the 6x9's but they sound fine and WOW! sounds much better than factory.
Let me tell you what though, the dash speakers are so much louder or should I say crisper than the rears, I gotta almost set all the sound to the rear.
Will a 4 channel amp help out to even the sound up? I know you guys will say get the kickers but I didnt have enough money for them..So what else can I do?
I got the HPF set to 125 also theres a function on my HU for EQ tune and when I click on it it has a bunch of mhz setting......whats that for? anything I should mess with?
thanks
Old Dec 2, 2002 | 10:37 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
I would think that the dash speaker are sounding more crisp because they are probably getting close to the wattage they need, whereas the rear 6X9s are underpowered right now. An amp will help out alot, especially since you have nice infinities.
Brian
Old Dec 3, 2002 | 01:23 PM
White Ninja's Avatar
it's better to have cleaner sounding front stage, since that's the majority of music you hear comes from - which is why people choose to install quality components in the front. I too believe that the 6x9s are just underpowered. if you were to amp them close to their RMS you will get the clean loud sound similar to the 4x6s, especially since Infinity is a good brand.
- Andy
Old Dec 3, 2002 | 01:33 PM
The 4x6 RMS is 40w with a MAX of 120w and the 6x9's are 100w with a MAX of 300w. My HU only pushes 52wX4.....does that mean that the speakers are getting 52 watts each right now with out an AMP?
so would that make either of the speakers unde powered?
Old Dec 3, 2002 | 02:13 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
If you gonna amp them, do all of them...
IT will dramatically increase you sound capability.
As far as the sony :nono:
Old Dec 3, 2002 | 04:15 PM
:sillylol: I knew you would step in here KJ and speak your piece about the Sony, it was just matter of time.
Old Dec 3, 2002 | 04:16 PM
seriously though, is that why the sound is off balance? cause the output of the HU is lower than the RMS of the speakers.
Old Dec 3, 2002 | 04:37 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Yes it will throw it off.
The actual output of the HU is only about 13w per channel.
Since your 4x6 require less power, they sound better.
Get a small decent amp, and they will sound really great.
I can recomend the Volfenhag amps. They are cheap, and as far as I can tell, work really good.
I have it powering my kicks, and 6x9's, and it is loud.
Good choice on speakers, but Like I said, sony
Old Dec 3, 2002 | 05:01 PM
but for $175.00 brand spankin new, never been used, I say the Sony HU is a great deal that couldnt have been beat, anywhere!
Ok, if it say 52x4watts for the HU, why are you saying its lower?
Does that also work for the speakers too?
Old Dec 3, 2002 | 05:23 PM
Hey, when looking for an AMP, what am I looking for? The RMS?
should I a 4 channel, bridgable amp with good RMS and max wattage? Hell I dont know....
Old Dec 3, 2002 | 08:24 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Well that is the MAX power rating, and it will never reach that without severly distoring the speakers.
Any Amp that can put out 50 Watts RMS will be good.
MAX Power ratings are decieving.
My Volfenhag is rated at 1000 Watts MAX.
But it only puts out about 75-100 RMS per Channel.
It is a 4 Channel amp. Perfect for running my kicks, and 6x9's.
I would recomend it. It's only like $130 on ebay.
Now that is a deal you cant beat.
It does pretty good on subs also. I was surpised when I tesed it out.
Not as clean at my RF 800, but still better than good.
Old Dec 3, 2002 | 09:39 PM
9177's Avatar
I just bought this alpine from crutchfield for 200. Im sure you can find it on ebay cheaper and it sounds very nice. I had the same problem KJ had with noise in my MTX amp so I bought this and have no complaints.
Old Dec 3, 2002 | 11:51 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
same amp at ikesound for $155, but you dont get the alpine waranty.
Just an FYI, not trying to be a d!ck to 9177
Brian
Old Dec 4, 2002 | 07:27 AM
9177's Avatar
no problem. the only real reason I buy from crutchfield is because I have a credit line there. Not to mention with my luck i will need the warranty before its up lol.
Old Dec 4, 2002 | 11:13 AM
fletch's RS's Avatar
audio logic is one of the best amps i have one powering my 2 12' memphis' and they sound pimp
Old Dec 5, 2002 | 07:24 AM
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
hey kj is the volfenhag ZX-7170 a good amp to run a single 12" sub and 6x9's? it has 1000W max and puts out RMS at 100 watts x 4 Channels @ 2 Ohms? amps is like a whole other language that i do not know to me
thanks
bub
Old Dec 5, 2002 | 05:02 PM
Huckster's '84 TA's Avatar
Car: 1984 Pontiac Trans Am
Engine: 5.0L
Transmission: TH700-R4
the reason the speakers sound out of balance is generally, smaller speakers are more efficient, which means they get louder with less power (in the upper range of course). I'd say get a nice 2 channel amp, brand name, 50 or so watts rms per channel and you will be good to go. good luck
Old Dec 5, 2002 | 05:05 PM
Engine: 5.0L
also that headunit puts out 23 watts rms. the EQ setting are there for people who like to tune their headunit to their tastes or to balance out the levels of the speakers. read up in you owners manual how to work it and play with the settings. you might find out that if you turn the higher frequency response down you might not have such a harsh top end. good luck again.
Old Dec 5, 2002 | 05:55 PM
yeah, thats what i'll do is look for an amp....but I thought its good to get a 4 channels amp so it can power all 4 speakers and then a sub if I ever get that....the guy and CCity told me that the best bang for the buck was a 4 channel Bazooka Amp they had there that puts out 60 watts rms per channel at 4 ohms..........only $199 but I can probably find it cheaper on EBay....
Old Dec 5, 2002 | 08:40 PM
Engine: 5.0L
the only problem with amping the 4x6's is if they cant take that much power. they are pretty efficient, so you dont want to blow them.
other amps to check out are mtx, rockford, kicker, alpine, kenwood
zupmanZ28
Dec 19, 2001 03:54 PM
hot86z-28
Aftermarket Product Review
Dec 10, 2001 03:56 PM
88greyiroc
Jul 22, 2001 02:58 PM
myposcamaro
Car Audio
Feb 28, 2001 05:20 PM
FAST RS
Nov 30, 2000 08:19 PM
