Pro's and Con's...???
Old Feb 26, 2001 | 03:37 PM
myposcamaro's Avatar
To those that know..
what are the advantages and disadvantages of running your Remote cable to the ignition fuse of the fuse panel?
now i already ran a toggle switch to turn the amp on and off at my will, but is there any other disadvantages other than "it will turn on whenever your amp's on"??
just wondering.. and this is just a lame attempt to contributing a little somethin somethin to this board.
kev
Old Feb 26, 2001 | 06:54 PM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
I'd say none whatsoever. If you hooked up JUST the remote wire to the fuse box's ignition, the wire should only draw something like 200mA max of current, very insignificant (anyone feel free to correct me on the actual current draw of the remote, i'm just guessing from memory)
  • '89 Trans AM, 305 TPI, 5-spd
  • '86 Firebird, 2.8, Auto
Old Feb 26, 2001 | 10:23 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The biggest disadvantage is that quite often you get a rather loud turn-on thump by doing it that way. The head unit usually delays the remote power ever so slightly until after there is signal present on the RCA lines. By running it directly from ignition (wire a .5 amp inline fuse) it turns on before a signal is present at the inputs, so quite often you get a loud thump.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Feb 28, 2001 | 02:26 AM
85ws6TA's Avatar
Car: '92 Typhoon/ '79 Vette
Engine: Turbo 4.3L/Forged 355ci
Transmission: 4l60/th350
is that bad for the sub? cuz i use the toggle switch (out of pure lazyness and not wanting to get behind the stereo) and i usually turn on the sub before the stereo and it does the loud thump
1985 WS6 Trans AM
T-tops
bone stock sloth of an engine LG4
T-5 tranny. thank god, i couldnt stand an LG4 auto.
Plans for an LT-1 or LT-4,
dual flowmaster exaust,
& a pounding stereo.
mods right now include a radar detector.
Old Feb 28, 2001 | 09:27 AM
Jim85IROC's Avatar
It's sure not helping them, but whether it does any actual damage would depend on how loud it is.
The IROC Homepage
Old Feb 28, 2001 | 04:38 PM
damn.. i coulda sworn i clicked "email notification". I had no idea i had 4 replies. Well anyway..
i dont get a loud thump at all? well i do... but its not very loud. It sounds like a mere "puh" when i hit the switch. Usually im already playin the music then i hit the switch, so i guess i wouldnt notice the "puh" anyway.. ill try with no music playin next time!
anything else from anybody? jim?
kev
Old Feb 28, 2001 | 04:53 PM
KlayBuRn's Avatar
when i had my Topaz, and was running switches, i just didnt bother going to the fuse panel, just run the remote wire through the switch and you wont have any problems...
i was running a pioneer amp on 2 6x9's, and a premier amp runnin 2 12's, ran 2 remote switches for 2 years, didnt have any problems or nuttin, as a matter of fact, i sold all that equipment to my bro and he still uses it to the day...
Old Feb 28, 2001 | 05:06 PM
klayburn..
but where did the remote cable end up at? from what i gather it sounds like you just hooked up the cable to the switches.. then.. the cable hooked up to what??
kev
Old Feb 28, 2001 | 05:13 PM
KlayBuRn's Avatar
i ran the remote out of the deck, it plugs into one end of the switch, the best example i could use, for my switches, my mom has some bazooka tubes in her dodge spirit, and i just used those, so they said SS on them, but anyways, then one plugs in to the switch, then the other spot on the switch, i ran another blue wire from the switch back to the amp, if you run more than 2 amps, you gotta splice, otherwise your switch will turn them both off...
Old Feb 28, 2001 | 05:20 PM
oh ok you ran the remote back to the deck.. see i didnt catch that the fist time, i thought u just had the cable running to the switches!?! i was gonna say 'what the hell turns on and off then'...
kev
F.I. 57 Belair
Aug 23, 2021 01:09 AM
tmellott89
Oct 14, 2015 02:06 PM
djmarch
Oct 2, 2015 10:41 PM
J.C. Denton
Sep 21, 2015 04:23 PM
3.8TransAM
Sep 17, 2015 02:16 PM
