ack think I need audio help
Old Dec 4, 2002 | 09:32 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
I am using a infinity perfect 10.1 sub with a cheap performance teknique amp
the amp is bridged
problem is that when the amp gets turned up above half way right now the speaker starts to get real distorted
also I can sometime hear something that sounds like a rattle or like a quick hit to a solid object come from the box
could it just be a ****ty box
a box that is too large or what
it does it on any amp I have tried
the box is about 14l*14w*6depth on top with 8"depth on bottom
what gives?
Old Dec 4, 2002 | 09:37 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
also does anyone have the stats on the 2chnl 200W+200W performance teknique amp?
Old Dec 5, 2002 | 05:25 PM
Huckster's '84 TA's Avatar
Car: 1984 Pontiac Trans Am
Engine: 5.0L
Transmission: TH700-R4
what other amps have you tried? that is a pretty nice sub, so it might be the lower quality amps you are using. distortion causes that.
Old Dec 5, 2002 | 07:01 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
the other amp I can't remember the name
sad thing is it is in my friends car and his MTX cheapy bottom of the line sounds better then mine
Old Dec 5, 2002 | 08:37 PM
Engine: 5.0L
i would suggest trying it out on a brandname amp that has at least 200watts. that will give you an idea if it is either the amp or the sub. good luck
Old Dec 6, 2002 | 06:06 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
well just put it on a rockford amp today
same thing
I dont think the speaker is blown though
is there a chance that the box is too large
I know the infinity perfect is supposed to be used on a small box but I don't know a lot about speakers yet as far as how much of a difference the box can make
and it is just some chitty walmart 20 box
Old Dec 7, 2002 | 03:48 PM
mudaholic's Avatar
the box will make or break your system.. do you know what size it is? if its off, spend 20 bucks on a sheet of 3/4" mdf, invest a couple hours time and you should hear a world of difference..
Old Dec 7, 2002 | 04:18 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
ok I don't have the right box size for the speaker anymore
does anyone have the right box size for the speaker
or can give me the right size to make each wall
thanks for all the help
Old Dec 7, 2002 | 04:21 PM
mudaholic's Avatar
you should have a box with 0.6 cubic feet of airspace..
Old Dec 7, 2002 | 04:34 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
ok now comes the question perfect square... of a tilted box like a typical hatchback desing
and does someone know the forumla for figuring out the volume of a triangle... I forgot it
Old Dec 7, 2002 | 06:13 PM
mudaholic's Avatar
for (at least thirdgen) hatchbacks, pointing the sub straight up will bounce the waves off the glass directly at you, which is a good thing.. as for the AREA of a triangle, its 1/2 * b * h, for volume you'd also need to multiply by depth...
Old Dec 9, 2002 | 02:20 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
hehe
me dumb
forgot it that simple
Old Dec 9, 2002 | 09:35 PM
TorchRay's Avatar
Car: 89 WS6 Formula
Engine: 305 TPI w/ some mods done
Transmission: Modified THM700R4
does the amp have a crossover built into it? My friends got the same problem.....turn it up load...and it distorts.
Nick Locking
Car Audio
Sep 30, 2015 04:24 PM
zayne0
Aug 24, 2015 07:22 PM
85ws6TA
Car Audio
25
Dec 16, 2000 05:24 PM
TomP
Nov 5, 2000 10:16 PM
Todd 92 Z
Car Audio
Sep 11, 2000 08:24 PM
