Why does this happen
Old Dec 20, 2002 | 05:21 PM
jsusoutherners's Avatar
my stock stereo on an 86 firebird ta fades in and out and so does the display???
i just recieved the car and am trying to get it going
Old Dec 20, 2002 | 10:04 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Somewhere you're loosing voltage/power. Either a connections is loose, or the battery or alternator is going bad.
Old Dec 21, 2002 | 06:00 PM
MdFormula350's Avatar
if everything else is working fine you most likely have a loose connection somewhere in the back of the headunit.
Old Dec 21, 2002 | 07:28 PM
yea i am pretty sure its the alternator.... by the way how much are those things running now??
Old Dec 22, 2002 | 09:18 AM
SlowMaro's Avatar
about 75 bucks for the alt. if the alt was dying , your car would cut off suddonly, all the time, like when you hit your brakes, or turn the stereo on, ..car wouldnt start at all ect ect, ...id say check the wiring/ ground.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
