Ok this is confusing
Old Jan 2, 2003 | 12:52 AM
xaivior's Avatar
Car: Camaro
Engine: 355
Transmission: th-350
Axle/Gears: 3.73 welded
Hey guys ...I got a small problem with my amps I cant figure it out. when I turn my amps on they light up bright then go dim (they have LED lighting on them) so I started playing with them to try and figure this problem out .. I found that if I take my remote wire and touch it to the power wire (from the battery) it does the same thing so that eliminated the switch being at fault . so I took a second peice of wire and made a jumper wire from the power wire to the remote wire leaving the remote wire from the switch connected sorta like haveing two remote wires and the amps worked fine until I turned the music up ..the amp that is on my highs totally cutout and the bass amp kept going i turn the volume back down and the highs kick back in. this one has me stumped ..unless my amps are half dead which would suck I have no $$ spent it all on suspension heh.
so what you guys think???
Old Jan 4, 2003 | 10:53 AM
82berlinetta350's Avatar
Where is your power wire connected at, and how secure is it. Same with your ground wire. Also, what size power wire are your running? I know it doesn't seem like that big of a deal, but you need to run at least 8 gauge. And make sure that your ground wire isn't too long.
Old Jan 5, 2003 | 02:50 PM
TireTurner's Avatar
it is all about the power wire connection, invest $4 at menards for some good terminals to connect to your battery and ground. make sure your ground and (+) are the same gauge, make sure they are a large enough gauge.
Galaxie500XL
Feb 1, 2020 04:53 AM
Jorlain
Oct 8, 2015 01:57 AM
sahlomonic
Sep 20, 2015 07:15 PM
bubbaz28
Sep 18, 2015 02:09 PM
Denricci22
Sep 18, 2015 09:02 AM
