Wiring rear speakers
Old Jan 7, 2003 | 04:52 PM
cailen's Avatar
I'd like to run some new wiring to my rear 6x9 speakers. What's the easiest way to do this?
Old Jan 7, 2003 | 06:49 PM
MdFormula350's Avatar
i would go under the carpet around the center console area and work your way back and then go under the rear seats and behind the plastic interior and up into the speaker.
Old Jan 8, 2003 | 01:37 AM
cailen's Avatar
Okie, so I need to take the console out and lift up the carpet, basically?
Old Jan 8, 2003 | 10:09 AM
i would it you dont want to see wires all the time.. under the carpet would be the best choice i think..
i would start with taking the center cosole out, that should give you enough room to tuck the wires under the carpet.
i am still using my stock wires, so i am not very experienced just trying to help. thats the way i would do it.. i would just leave my stock wires in also..
Old Jan 8, 2003 | 05:26 PM
cailen's Avatar
Think I'll take your advice and just use the current wire in my car
Thanks a lot bro
Old Jan 9, 2003 | 10:33 PM
well you could leave te stock wires in there but also run some new wires if you want.. i am sure new wires would be alot better than the factory stuff..
good luck either way..
Old Jan 13, 2003 | 09:01 PM
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
i did it an easier way.....just took off all the moldings around the doors and ran the wire from the hu up the dash under the dashpad....down where the kickpanel would be....along the door rail underneith the carpet a little....then up the rear seat panel.....i found it much easier that way
Old Jan 13, 2003 | 09:11 PM
or you could do that
Old Jan 23, 2003 | 07:41 PM
patrickm00's Avatar
i rewired my GTA after one rear wire frayed out, i would say the door sill approach is certainly easier
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
89lsc
Aug 14, 2015 04:58 PM
