Pos and Neg wires
Car: 1988 IROC
Engine: 5.7
Axle/Gears: 2.77 posi
easy test... hook up a 9 volt battery to the wires BRIEFLY!!!
WATCH SPEAKER AS YOU DO AND IF CONE MOVES TOWARD YOU, WIRING IS IN PHASE TO BATTERY.. IF CONE MOVES AWAY, THEN WIRES ARE BACKWARDS
If you blow your speakers from that test, then the speakers should be blown because they are about 5 - 8 watt speakers MAX, 9-volt batteries only put out 500mA or .5A which works out to 4.5 watts of speaker blowing power
In my experience, speakers cannot be blown from a 9-volt battery. Take from an installer who frequently has to double check factory speaker wiring. EVEN FACTORY SPEAKERS CANNOT BE BLOWN WITH A 9-VOLT BATTERY
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
db057
Aug 11, 2015 10:11 PM
