View Poll Results: What do u think? 1=bad 5=YES!
22.22%
16.67%
33.33%
11.11%
16.67%
Voters: 18. You may not vote on this poll
cool idea for subs in backseat!!
Old Jan 19, 2003 | 05:00 PM
84Z28_5.7ltr_V8's Avatar
Car: 1984 Z28
i was thinking, maybe someone could take out thier back seats entirely, and put a sub wehre you put your a$$. like lay a board across it and cut a hole. you would obvioulsy have to do some precision cutting to make it look flush, but that would be MEAN!!! and then put your amp where you would normally lay back!
Rate it on a scale of 1 being terrible, and 5 being, im going to go do it now.
Old Jan 19, 2003 | 09:27 PM
MdFormula350's Avatar
i voted three..
maybe you could leave your seats in, and just fold the top down and mount the box onto the back of the seat.
Old Jan 19, 2003 | 11:38 PM
Car: 1984 Z28
or some how put in a locking system so the box wont slide around, and when you have more people you need to drive you can unlock it and put it in the back? as long as it isnt to big i guess.
Old Jan 20, 2003 | 02:25 AM
zer0321's Avatar
not to burst your bubble or anything, but I've seen pictures of it done around here somewhere....
and if you do do it, take your back seat out, I think it would look kinda tacky having the seat folded down "permanently" with a box on top of it....
Old Jan 20, 2003 | 05:37 PM
Car: 1984 Z28
lol. i know that.
Old Jan 20, 2003 | 09:20 PM
mudaholic's Avatar
personally i think it looks gay in a daily driver. if you are running a competition spl car or something, then i could justify doing it.. but otherwise it just looks tacky to me.
Old Jan 20, 2003 | 09:44 PM
Car: 1984 Z28
i would probably only drive it on weekends and holidays, no point really in driving it to work every day, i have a chevette for that.. lol unless you still consider that a daily driver.
Old Jan 21, 2003 | 09:52 AM
jawzforlife1's Avatar
I had two 12" subs behind the front seats. I took out the back rest, and put the box on top of the bottom part ot the seat, Had to make a small cut out for the hump. Then I cut the front of the box at the same angle of the back of the front seats (matched perfectly) But the face of subs were not right behind the seats, i pushed them into the box about 6 inches. I have pics at home, If I remember I'll post later tonight.
I have made may boxes so it was easy for me, but if you've never done it before, I'll want to do alot of meassureing and plan drawing, i got mine so perfect that the back corners of the box sat on the brackets that hold the backrest in.
Old Jan 21, 2003 | 06:43 PM
Car: 1984 Z28
get some pics of that set up, sounds nice!
Old Jan 21, 2003 | 07:23 PM
here ya go. And no the interior is not that fadded, its just the picture.
I than got a peice of black furry material and ran it from the seats to the real "well"
Old Jan 21, 2003 | 07:34 PM
Old Jan 21, 2003 | 10:14 PM
Car: 1984 Z28
well thats a pretty nice set up.. if you had some dimensions for the pieces you cut that would be nice.. :hail:
Old Jan 21, 2003 | 10:38 PM
I accually have it in my basement, I'll take some messurements tomorrow.
Old Jan 22, 2003 | 06:55 PM
Car: 1984 Z28
thanks!
Old Jan 22, 2003 | 09:57 PM
I took the messurments off my box, I is carpeted so they are not exact, but they should be within the 1/4 inch. Any queztions let me know, Also I take no responsibility if you make this box and it doesnt fit. Worked great in my car though. I made this for two Rockford 12" XLC's, I think the inside volume for each sub is just over 1.5 cubic feet.
Here ya go
Attached Thumbnails cool idea for subs in backseat!!-backseat-box-dementions-j.jpg
Old Jan 23, 2003 | 01:50 AM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
hmmm....
There is a enough room there to fit 3 12's or perhaps 4 10's with a setup like that. 4 10's would be killer. The airspace is not a problem it's just the width of the box that could be a problem. you could, with 10's pu them high /low as they sit in the box, you know like one 3-4 inches lower than the one beside it, that way you have enough space across the face of the box.
Old Jan 23, 2003 | 09:15 PM
Car: 1984 Z28
330hp, i dont get it. And i do have 2 tens and was going to get 2 more... if what you are saying is true.. then yes!! ill do it!!! also. what the hell are u talking about putting one lower then the other.
Old Jan 23, 2003 | 09:17 PM
Car: 1984 Z28
nevermind.. i see what your saying.. this is with the backrest not in the car right....
Old Jan 23, 2003 | 09:37 PM
backrest out, bottom seats in.
Old Jan 23, 2003 | 09:59 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
you sure...
You know, you just off-set the subs ( not aligned next to each other) in order to mount them closer to each other. It would be best to do with tens because of the space issue.
If you were planning on getting 2 more tens, then do it! It'll rock!! Just remember that if you are going to do this, sealed is really your only option, with 2 divided chambers and 2 10's per chamber.
Hey JawzForLife: What cubic foot measurement did you come up with ?? I don't feel like doing the math.
Old Jan 23, 2003 | 10:04 PM
I think it is a total of just over 3 cubic feet, I could be wrong, but that is the rought est I came up with, with the "outside" mesurements. If that is too big of a volume you can make you dividers in the box bigger to take up more space.
Old Jan 24, 2003 | 01:46 AM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Ok, I did the math and used the inside measurements. It's right around 3 cubic feet, a little less like 2.94 or so. with a divider it'll drop to 2.85 cubic feet.
So that's 1.43 cubic feet per set of 10's which is plenty. That means you can use a 10 that requires anywhere between a minimum of .55 and .85 cubic feet. That's not hard to find for a 10.
84 Z-28: What 10's do you have now?
Old Jan 26, 2003 | 09:56 PM
Car: 1984 Z28
i have 2 ten inch pheonix golds. i might buy 2 more and a PG amp as well. do they make headunits too?
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
