capacitor setup
Old Jan 21, 2003 | 10:24 PM
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
capacitor setup
hey, i was wondering if any of u had a close up picture of how ur capacitor was hooked up to the power cable of the amp......im a little confused on how this hooks up.....do i make a T or do i butt the 3 ends up together.....thanks
Old Jan 21, 2003 | 10:37 PM
White Ninja's Avatar
here ya go
Old Jan 21, 2003 | 10:44 PM
bubbakutz's Avatar
Engine: LG4
so basically i cut the amp wire.....strip the rubber.....wrap it around the cap and do the same to the other end of the cut wire?
Old Jan 21, 2003 | 11:47 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Use ring terminals to connect the wires to the cap. An try to make the wire from the cap to the amp as short as possible!
Old Jan 22, 2003 | 11:25 AM
BASICALLY yes, use Ring terminals.
- Andy
Old Jan 22, 2003 | 12:14 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Make sure you charge the cap first unless you like fireworks and a spent cap. The cap should have come with a resistor to charge it with. If not, use a test light. You charge the cap simply by grounding the negative terminal, and applying power THROUGH the resistor or test light to the positive terminal of the cap. A test light is easiest because you just leave it connected until the light goes out. If you're using a resistor, keep it connected for a few minutes.
Old Jan 22, 2003 | 02:24 PM
bubbakutz's Avatar
Engine: LG4
ok....thanks.....this is what the cap came with.....i know i have to ground the black wire but where would be the easiest place to hook up the red wire to charge the cap?
Old Jan 22, 2003 | 05:53 PM
??The battery?? Charge it with the battery before you connect it to the amp and stuff.
- Andy
Old Jan 22, 2003 | 07:17 PM
bubbakutz's Avatar
Engine: LG4
ha, ok...
Old Jan 23, 2003 | 02:33 PM
HamsterOnaMission's Avatar
isn't it dangerous to be working with (ie playing with connections, hooking up wires) a charged capacitor that large?
Old Jan 23, 2003 | 03:43 PM
Jim85IROC's Avatar
If you're an idiot, then yes. If you treat it just like you'd treat a battery, then you'll be equally as safe as when you handle a battery.
Old Jan 23, 2003 | 03:56 PM
yeah, in other words, when it's charged, be careful....and don't touch the terminals together!!!
- Andy
Old Jan 23, 2003 | 04:14 PM
bubbakutz's Avatar
Engine: LG4
how long does it take to charge?
Old Jan 23, 2003 | 04:38 PM
Jim85IROC's Avatar
It depends on what value resistor they give you. Figure around a minute or 2.
If you use a test light (highly reccomended), just keep it there until the light goes out.
Old Jan 23, 2003 | 04:43 PM
bubbakutz's Avatar
Engine: LG4
ok, thats waht i thought.....my cap came with the little led light on the top to tell me when i was done
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
