6x9 boxes
Old Jan 22, 2003 | 09:48 PM
HaroGt14's Avatar
6x9 boxes
I just bought some Audiobahn FLame 6x9's for $100 brand new. And I have heard that they only use their full power in a box and with an amp. I was wondering if anyof you have ever experienced 6x9's in our cars? Did you make your own? Did you buy some custom ones? It looks like there is very little to no room to fix a regular box back there.
Sean
Old Jan 23, 2003 | 03:15 PM
jawzforlife1's Avatar
I bought some 6x9 boxs at wall mart for $30, ,I bought them for my truck, (which only has 4x6 speakers in each corner) but never used them, so I dont know hw much they help.
Old Jan 23, 2003 | 03:39 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
The max output depends on what you have for a head unit, amplifier, cross overs and noise filters. The stock location in the towers of thirdgens is typically factory equipped with 6x9s. These speakers were not typically intended for use in a box, but rather in factory locations (doors, dash, and so on) but no speaker is hurt by putting it into its own enclosure. Typically, 6x9s will work well right off of a good deck with no amp, but a 120-240 watt amp will work best. If you plan on a whole system, a 4 channel 700 watt amp would be perfect.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
