whats everybody's secret to connect their wires?
Car: 85 trans am
Engine: 79 4 bolt 350
how do you guys connect all of your speaker, radio, ect. wires? i have used solder before but it was a little messy but they stayed connected and everything. iv also just twisted them together and taped em. i think im going to try some connectors and crimper plyers as soon as i get my new cd player.
Twist and Tape is BAD...when electrical tape gets hot which it will under the dash, it will start it unravel leading to touching wires :-\
I use connectors on all my stuff, solder is good, if your good at it and i'm not :-)
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I use butt-connectors exclusively. I don't like solder in the dash because solder can crack when you stuff the wires back in. With the butt connectors it seems to be more reliable as long as you crimp them properly, and use wire ties to bundle the wires on both sides to remove the stress from the connection.
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Heat shrink rocks! Then there is the Tamiya flat style connectors they use for R/C Cars. These are good and cheap. Plus they kind of look professional.
Car: 89 Camaro I-Roc z
Transmission: Th700r4
i sterted using tape and wrap. that sucked.
i gradueated to sodering, it was cool but it has flaws of universal comatibility.
then i started crimping, but the connectors were bare.
so now i use crimping connectors and i dip it in something called liquid tape that covers it completly and looks very professional.
Car: '87 SC
Engine: 2.8L
Originally posted by wyclefsirocz
crimping them s th only way, clean,net andlooks pro. crip the , but just do it right
I use butt-crimpers. I had ones with plastic covers behind my head unit, but ended up removing it and redoin the wiring harness, and got butt-connectors that were bare. I ended up wrapping each one up with a couple layers of electrical tape and I've never had a problem. Personally, if done right, I imagine the connectors would be more secure than sodering.
Car: '91 Firebird vert
Engine: 305 TBI
Transmission: auto
on my car (when i had a system): twist caps and butt connecters.
on other people's cars when i do installs: tape. electrical tape, duct tape, even used medical tape once (it was all i could find).
Car: 89 Camaro RS
Engine: 2.8L V-6
I use butt connectors most of the time. I try to use connectors on everything I do, from headunit wires to amp power wires and speaker wires. I ahve seen that liquid tape stuff, havent tryed it yet though. Looks like it would look very proffesional.
Car: 85 Z28
Engine: LG4 modified
I always use bullet connectors (I think it's the same as your butt connectors), and if I'm wiring to amps etc. I use gold plated ring connectors.
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
i've soldered and i've used butt connectors. tape is only to go over the soldered or crimped areas. twist and tape is one of the worst ways to wire in a car. i gotta get some of that liquid tape someone mentioned around here. shrink tupe is nice for covering up too. i also like to do the wire tie thing to tidy up back there.
Originally posted by HamSpiced
tap-in things?
tap-in things?
http://www.mcmaster.com/catalog/109/...e/7063kp1l.gif
Thats what I was talking about.
Best--- Solder and heat shrink
Good--- Butt connectors
Worst--- Wire wrapping
I have been installing 2 way radios for over 15 years and the noticed the best connection to be soldering. I do alot of goverment work and some demand that we solder and heat shrink everything. Crimping is great but in my car it's only soldering for me.
The larger guage wire in the pic is the wire you are trying to get your signal from, the smaller wire is the wire thats getting tied into the main wire. That piece of metal gets pushed through the insulation of the main wire and contacts the copper inside when you close the latch on the top. The other side of the metal piece is connected to the smaller wire.
if you solder well, that's electrically the best connection, but there are some problems in terms of automotive use (cracking when cramming wires into tight spaces, disassembly later). you also have to make sure you use compatible materials to avoid corrosion effects.
Car: 1994 Nissan Pathfinder
Engine: 3.0L V-6
as has been mentioned, i have come to the following conclusions in my own experiences:
1. soldering provides the best connection; therefore the best power propagation and sound quality
2. heat shrink provides the "security blanket," if you will, that protects the solder connection.
3. twist 'em if you don't have any friends or skills with soldering. but ONLY as a LAST resort.
that's just my $0.02
db057
Aug 11, 2015 10:11 PM
