amp problem
Old Feb 13, 2003 | 11:02 PM
quicklil87lt's Avatar
amp problem
i just picked up a coustic 600se. i have run into a roadblock though. it will go in a nd out of protect. it will be fine for like 2 seconds and go into protection mode. it will stay in protection mode for like 10 seconds and then go fine for another couple of seconds. i checked all the fuses and my other amp works perfectly fine with the same wiring.
Old Feb 14, 2003 | 12:34 AM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
what ohms are you running at? it may be too low for that amp. or the amp may be dead...
Old Feb 14, 2003 | 01:10 AM
i didn't even have the amp hooked up to any subs or anything. i just tryed running power, ground and a remote wire to it to see fi it would power up. no speakers or rca's hooked up to it at all. i think the amp might just be fried. even if it is i got it for free so it wouldn't be too bad.
Old Mar 1, 2003 | 05:57 PM
TFM4th's Avatar
Car: 87' Firebird
Engine: 2.8L
Transmission: Standard
hey did you figure out what was wrong? im having the same problem... mine might have something to to with the ohms im guessing... i have a 300W max amp running 1 MA audio 600W max sub? is there just not enough power maby?
Old Mar 2, 2003 | 11:27 AM
Huckster's '84 TA's Avatar
Car: 1984 Pontiac Trans Am
Engine: 5.0L
Transmission: TH700-R4
what type of power wire did you run to it?
Old Mar 2, 2003 | 04:31 PM
TFM4th's Avatar
Car: 87' Firebird
Engine: 2.8L
i ran a skinnyer type of wire... not what i should have i know but all i have 4 now. but i ran a bunch of wire to the amp from the battery, to see if the amp just wasnt geting enough power.. but it made no diffrence
Old Mar 2, 2003 | 05:05 PM
HaroGt14's Avatar
I have had a couple of amps do that to me. Where it would power up for about 2 seconds and then go into protect. Come to find out they were blown. Sounds to me like that amp is blown. Open it up and check for blwon resistors and such. Or give it to a shop to rebuild. That's just my $.02!
Sean
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
