new deck problem with headlights
Old Feb 18, 2003 | 12:17 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
i just got a kenwood kdc519 deck and now when its on the lights like dim alot and then do a strobing affect or just go off
Old Feb 18, 2003 | 09:14 AM
spike1856's Avatar
Car: '86 SC
Engine: '88 2.8L
Bigger alternator, bigger wires from battery to alt to ground....
Old Feb 18, 2003 | 09:27 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The deck should never cause your lights to dim. If you have more than a 10 amp draw, you'll blow the factory fuse. I suspect that your charging system has some serious problems, or you have a problem with your wiring. Did you ground your deck to the brown wire or to the black one? If you ground it to the brown wire that's in the separate plug with the orange wire, you'll have big problems when you put your lights on.
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
mustangman65_79
Car Audio
Sep 30, 2015 09:37 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
