Here is a pic I found
Old Feb 27, 2003 | 03:34 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
Battery in back next to subs under cap, 1.5 farad cap, 2 10" Rockford punch subs, 2 12" Kicker Solobarics,
Sherwood 75x4 amp for the 10's and the front speakers ( Boston Pro series tweeters, Oz 5 1/4 mids, Oz 4 inch mids)
Audiocontrol 2 way X-over for this amp.
Alpine 30x2 amp for the rear ( bridged to 4 way pioneer 6x9's)
Rockford 200x2 amp running the solobarics in parallel ( 1 ohm )
Sheet with amp says brideged @ 14 volts= 624 watts @ 4 ohms....1 Ohm?
Pioneer Head unit and a Clarion EQ
This is a pic with everything uncovered...you get the idea. When it is covered the only thing visible is the 10's. It's all covered in gray vinyl.
Old Feb 27, 2003 | 03:35 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
darn-it!
This was supposed to be a post on another topic. Sorry.
Old Feb 27, 2003 | 04:18 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Didnt solobarics usually have an S on the cap, not a K, look like comps to me...
Old Feb 27, 2003 | 04:54 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
yeah solo's were also square shaped right? just clean it up and that setup would be nice.
Old Feb 27, 2003 | 06:00 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
New solos are square, old ones were round.
Old Feb 27, 2003 | 07:45 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
The old Kicker Solos did come with a K. Then later models had the S.
Old Feb 27, 2003 | 09:26 PM
Supercharged84Z's Avatar
Car: 1984 Camaro Z28
Engine: 350 CID
Transmission: Beefed up 700R4
that looks like a mess to me...isnt it reccomended(sp) that you not mix-n-match subs?
Old Feb 27, 2003 | 11:12 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
yes, its really not a good idea unless you really know what you're doing. power levels, placement, phase all can wreak havok with multiple subs... especially in a car like ours
Old Feb 28, 2003 | 12:07 AM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Ok fellas.
READ!
It's not a mess!
That all gets covered up. Totally stealth, you cannot see anything except the 10's.
As far as mix-matching subs:
It's called different croosover points.
The solo's play 50hz down, the 10's play 50-100hz.
This gives the best sound quality.
This is pretty much a competition setup....but I can't find the pics of the door panels and stuff. They're all in Hawaii.
MAKE SURE YOU GUYS KNOW YOU **** BEFORE YOU POST!
i.e. " Solo-Barics are round...those are comps."
Old Feb 28, 2003 | 01:38 AM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
you need to check out your sources. until this year or last, kicker had a round solobaric. they also have the L5s and L7s.
Old Feb 28, 2003 | 09:39 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Dude....... I gotta ask
Where did you get a Sherwood amp? That was my first amp ever Back then (1987) they were a great value, but I haven't seen one for a LONG TIME!!!
Brings back mammaries of high school ....... I mean memories
Old Feb 28, 2003 | 11:04 AM
Car: 1988 IROC-Z
:sillylol: hehe
Old Feb 28, 2003 | 11:56 AM
Eric86TA's Avatar
You have got a lot of power and ground wires crossing and zig-zagging around all you RCA's and speakers wires. Do you not get interference from that wiring setup?
Old Feb 28, 2003 | 12:13 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
No. It's all mounted on a board, non-conductive.
As long as you run power wire on one side of the car and RCAs on the other...you shouldn't get any noise.
Old Feb 28, 2003 | 01:00 PM
transam305's Avatar
Car: 1989 White Trans-AM
Engine: 305 TPI hopefully Upgraded Soon.
Transmission: Crappy Needs Improvment.
i'm sorry but that looks like a vary scary setup IMO i would try and sqeeze all that into the back of my car i'd stick with either the 10's or the 12's i wouldn't mash both of them into the tight space of the back of our cars. but that's just me...
Old Feb 28, 2003 | 02:44 PM
Eric86TA's Avatar
I'm not sure who told you everything is fine as long as you run your power down one side and RCA's down the other. That is true, but any time that wires are bundled together or laying by each other there is a chance that noise can be coupled in from one to the other. Thats on a conductive or nonconductive surface. At some point everyone has to cross wire and in that case the best scenario is to have them cross perpendicular (90 degrees) to each other. Just some information for you.
aaron7
Aug 17, 2016 06:02 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
bjpotter
Aug 12, 2015 06:06 PM
BrianI
Aug 9, 2015 11:52 AM
antares57
Aug 6, 2015 07:47 AM
