140 amp alternator
Old Mar 12, 2003 | 07:54 PM
TallWhiteGuy's Avatar
Car: 1990 rs, pride and joy
Engine: 305 tbi
Transmission: t-5
140 amp alternator
Now i have heard you could put one in but would i have to get new wiring or just stick it in there? Also where could i get one
Old Mar 12, 2003 | 11:07 PM
Chevyguy1984's Avatar
You can get one out of a 1994 transport minivan with the 3.8L engine and rear A/C. You'll need the GM adapter harness to go from the stock 2 wire setup to the 4 prong plug on the new alt (GM part # 12083462 costs about $15). You should be able to bolt it right in, but I'm not positive since I did this swap on my monte and not on an F-body. When I put it in my car I made a new upper bracket using spherical rod ends and an aluminum turnbuckle. I also added an aftermarket regulator to give me 160amp capability.
Old Mar 14, 2003 | 02:30 PM
Eric86TA's Avatar
Ohio Generator makes a 140 amp alt for 3rd Gen. F bodies. I got a quote for about $425 for it from a web site called amp man. If you go to their site, there is a form that you have to fill out that tells them what all equipment you have in your car and what kind of car you have. A few days later they will reply to you with suggestions on what size alternator you need. The one they had for me was a straight bolt on. You do need to upgrade your stock wiring. I upgraded to 4awg even with my stock alternator.
Old Mar 14, 2003 | 04:35 PM
87GTA Runner's Avatar
Car: 87 GTA
I got a chrome Power Master from Summitt for around $150-$160.
Old Mar 15, 2003 | 03:00 AM
mrbboy's Avatar
I am running the PowerMaster 140 amp in my 91 RS. The install is very easy and it works great. I got it from summitracing.com for $135.
Old Mar 15, 2003 | 03:10 AM
radiateu2's Avatar
checkout www.alternatorparts.com
Old Mar 16, 2003 | 09:19 PM
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
i have one
Old Mar 17, 2003 | 07:47 AM
tyty49's Avatar
Car: 91 Maro & 97 Ram & 05 Roadstar
Alt. Company on eBay that sells 140 & 105 amp alts. They all come with a 1 year warrenty. I got the 105 amp one and it works great. Gettin it on was a boitch
RS Reaper
Oct 17, 2018 07:52 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
