Will this work?
Old Mar 27, 2003 | 02:29 PM
E-man007's Avatar
Will this work?
Im going to install a Q-logic box for two 10's and loading it with a pair of Audiobahn flameQ series.I seen a couple set-ups here with the speakers inverted so that the baskets are on the outside and they look sweet like that.Im thinking of doing that with my box.But I as thinking since the Q-logic box fires the subs at a slight angle towards the front and all the weight of the sub will be at the top,is there a chance that the speakers will break the mounting ring around it over time or if I go through a speed bump a tad to fast?
Also,I heard that you have to wire it different by reversing the polarity or something like this so that it doesn't sound nasty.How would I do this?
Thanks for any info!
Old Mar 27, 2003 | 02:41 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
The only concern I would have it the subs hitting the hatch when it's closed. I've seen those boxes (if it's the same one) and you'll have to check that first.
To wire them opposite, just switch the pos wire coming from the amp to the negative terminal of the speaker, and vise versa. Just make sure you do bofe-of-em or you won't get no bass.
It shouldn't break the box. If it does, that's just more of a reason to make your own.
Old Mar 27, 2003 | 02:55 PM
E-man007's Avatar
I'll look into that.Thanks for the info.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
