Can mounting an amp directly to metal cause alt whine?
Old Apr 4, 2003 | 12:56 PM
SeeYa's Avatar
Car: 91 RS
Engine: 5.0
I finished installing a sony xm-7557 and I'm hearing a slight hum form the alternater. The power wire coming in is 4 guage split into two 8 guage for the different power supplys. The ground (until I get more 4 guage wire) is a single 8 guage. I'm pretty sure the problem is the ground but a friend told me the whine could be from the amps chasis being screwed to the car's chasis.
Is this true?
Old Apr 4, 2003 | 01:02 PM
onebadwagon's Avatar
make am amp rack, and find out. it sounds possible. amps werent designed to be grounded by the body of the amp.
adam
Old Apr 4, 2003 | 01:30 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Sony.
Check your gounds.
But it's a high possibility that it's just your amp....
Old Apr 4, 2003 | 02:59 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Sony amps aren't known for their quality, but they should at least be good enough not to have whine.
Yes, mounting the amps directly to metal can create a ground loop which results in alternator whine. This is why a lot of amps come with plastic inserts that the mounting screws go through. The case of the amp is grounded, so if you attach it to the chassis, you wind up with 2 ground paths which can cause a ground loop, especially considering that in most cases you're just screwing into sheet metal which doesn't make the best ground.
Also... if your amps are screwed to the floor above the gas tank, I would HIGHLY reccomend you find a new way to mount them. In the event of a rear-end collision, do you want a bunch of screws 1/4" above the gas tank?
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
