Help,Sub doesnt fit in box!!!
Old Apr 7, 2003 | 11:55 AM
E-man007's Avatar
I have two Audiobahn flame Q series subs and was planning on putting them in the Q-logic enclosure. When I was test fitting them the magnet hit the bottom and the sub has about a 1/4 to 1/2 inch space between the box and the ring around the sub.
I was thinking of making some custom spacer rings made of wood to lift the speaker up a little and allow me to screw the subs in place.Will this affect the sound quality? Any other ideas? I dont want to buy another box, any tips are appreciated.:hail:
Old Apr 7, 2003 | 11:58 AM
88TAJeff's Avatar
Car: 88 T/A
Yeah , that custom ring idea works. I've had to do that to get speakers in doors before, and it worked out ok.
Old Apr 7, 2003 | 12:03 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
I did that to fit a 12w0 into a truck "wedge" box in which they cut the hole a little higher than the other. Sounded fine; friend of mine still uses this setup in his MX6 (sold it to him).
Old Apr 7, 2003 | 12:15 PM
E-man007's Avatar
Im going to try that .Thanks for the fast reply,I appreciate it.:hail:
Old Apr 7, 2003 | 12:53 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If the audiobahn has a vented pole piece, the rear should be at least a couple inches from the back of the box or it can cause the speaker to react in an odd way and can make funny noises because of the airflow through the pole piece.
Old Apr 8, 2003 | 11:06 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
use the ring idea liek you had and, i had an MTX RT 8000 a while ago but i couldnt afford a custom box for my back hatch, i inevatibly used a truck box that fit in the hatch area. The sub was way too big for the box so i made a trim ring, and i went to the hardware store and bought some of that foam stuff that you put between doors and moldings and it is even used as cheap weatherstripping for cars like mustangs (thats what the picture on the package looked like) anyway i wrapped that stuff around the side of the sub and then screwed it in... worked excellent for the time till i sold the sub with the box.
Street Lethal
Apr 30, 2019 12:14 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
MyRedCamaro
Dec 29, 2015 05:16 AM
Dyno Don
17
Nov 2, 2015 11:43 PM
Firebird sweden
Aug 16, 2015 05:02 PM
