Where to conect my power wire?
Old Apr 7, 2003 | 01:00 PM
85TPITransAM's Avatar
I have a problem. I connected my new poineer HU to the factory connections and now I'm blowing out the nuber 11 fuse. It was originally a 20 amp and even with a 30 amp it still pops. Where can I wire my power wire to to allow for the memory to be kept but only come one when the key is turned? Thanks
Old Apr 7, 2003 | 02:50 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You either goofed up the wiring or that deck is smoked. That deck should NEVER smoke a 30 amp fuse. A 15 amp fuse should be sufficient.
Old Apr 7, 2003 | 03:18 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Run a wire from that battery.
Do you have anything else hooked up to your Acc wire.
Otherwise it sounds like you are grounding out somewhere.
BRoss99
Aug 10, 2025 05:08 PM
Bert87
Aug 23, 2015 03:50 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
stalkier
Aug 13, 2015 12:59 PM
ZsTransAm
Aug 11, 2015 07:30 PM
