Questions, etc.
Old Apr 14, 2003 | 10:27 AM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
Questions, etc.
First off, I'll tell of my most recent experiment...I was recently employed by a local pro audio store, (all home theatre type stuff), which deals in the higher-end equipment - subs, powered towers, etc. Yesterday I obtained a 10" sub driver out of one of the subs, and since it was free, and the screw mounting pattern was the same, I figured 'what the hell' and installed it in a nice ported box. I know the issue of ohms home subs vs. car audio, but all I can say is WOW....this thing DESTROYS. I've heard the Alpines, Infinitys, etc., but nothing matches the range and sheer power of this sub. The company is Nuance, you can look them up on audioreview.com, I think...but the sound is unbelievable. Now, my question - I'm a bit new when it comes to wiring and amp installation, but the amp I have is similar to the red Xplod amp shown here, http://www.mz3.net/articles/187.html though it's a fair bit longer on either end - it has the onboard EQ, etc., and all of that - but only one independant 'subwoofer' out. It does has a variety of other outputs, enough to power the rest of the car, so I imagine I can use, say, the outs for my rears to power the second sub? It's all just signal, right? I wish I could find the exact amp so ya could see what I mean..I'll keep looking tonight.
Old Apr 14, 2003 | 12:53 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It's a sub meant for a home system? If so, it's probably an 8 ohm sub- but check the specs on the sub first. Car audio uses 4 ohm speakers. Since the sub's load is less, an amp can power it harder. You've basically cut the wattage to that sub in half, since the home-audio-sub is 8 ohms.
What you could do for a second sub is wire it in parallel with the first sub. Two 8 ohm subs in parallel shows a 4 ohm load to the amp. And that saves you from having to use your rear speaker outputs to drive a second sub.
Just make sure the Nuance sub is 8 ohms. It's probably written on the magnet somewhere. Also think of how well the sub can handle extreme 100-degree-day-parked-in-sun-with-windows-up temperatures.
Old Apr 14, 2003 | 01:30 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Not necessarily true....
I've seen 32 ohm home audio speakers, 8 ohm car speakers, and 2 ohm car speakers, etc. It can vary greatly. I had 8-ohm JL audio car-audio subs in my truck.
But yeah, if you're not overpowering or overloading anything, and it pounds, more power to ya.
Old Apr 14, 2003 | 04:25 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
LOL, that's why I said "probably", and told him to check the specs.
Old Apr 14, 2003 | 08:51 PM
Azure's Avatar
Excellent, thanks guys...I wasn't sure if I could do 4 into 8 safely or vice-versa. Woo!
RedLeader289
Jan 22, 2016 03:05 PM
dutch930
Sep 11, 2015 06:58 AM
theurge
Aug 21, 2015 12:46 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
