Radar Detector Wired into CD Player
Old Apr 23, 2003 | 07:03 PM
MartyMcFly's Avatar
Car: Z28
Engine: Edelbrockified 305
Transmission: 700-R4
So I've got this Valentine 1 Radar Detector and it came with a kit to hard wire it into the vehicle's electical system (instead of a cigarette lighter). Any way, does anyone see any problem with me wiring it in to the power wire for my CD player? The Valentine draws very little power - the fuse is only one amp.
Old Apr 23, 2003 | 08:00 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Should be fine.
Old Apr 24, 2003 | 05:54 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You could always wire it to the cigarette lighter wire; I did that with my Uniden detector. Don't forget to install a fuse on the detector's wire!! I ran my wire up along the a-pillar on the passenger side, and brought it out at the base of the "swivel" for the passenger's sunshade. I tagged a piece of velcro to the sunshade so if I'm feeling friendly, I can unplug the radar detector, put it away, tuck the wire end under the velco, and the passenger can use the sunshade.
Old Apr 24, 2003 | 06:56 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Yeah, If it came with a thing for the cigarette lighter also, That will have a fuse in it. Take it apart to see what Kind of fuse it is. (Amp rating) or it might say somwhere in the Radar Book.
Anyways yes you can hook it up to the powerwire on your hu. But use an inline fuse the same rating as the one in the cigarette adapter.
Old Apr 26, 2003 | 12:55 PM
MartyMcFly's Avatar
Car: Z28
Yeah the kit it came with is sweet, with an inline fuse like on my amp power wire. I'm thinkin I'll hook it into the power wire for the CD player so it won't get constant power. The wire for the radar detector is narrow enough that I can run it along the forward edge of the headliner and then along the A pillar so I won't have to cut anything.
Old Apr 26, 2003 | 05:43 PM
tyty49's Avatar
Car: 91 Maro & 97 Ram & 05 Roadstar
you should let us know how well that radar detector works.
Old Apr 26, 2003 | 05:58 PM
Supercharged84Z's Avatar
Car: 1984 Camaro Z28
Engine: 350 CID
Transmission: Beefed up 700R4
from a report i read...its supposed to be one of the best...good choice
Old Apr 26, 2003 | 06:35 PM
tyty49's Avatar
I know thats why I want to see how well it works for him.
Old Apr 26, 2003 | 06:36 PM
VampireHunterC's Avatar
Not really sure how well this would work in a Camaro, but a few years back, I drove a Toyota something-or-other home for my girlfriend's mom, and it had a metal L-bracket on the dashboard (kinda on the side of the gauge cluster, 'cause the cluster was one of those that "humped up" from the dashboard), with a small hole drilled in the dashboard where the bracket was mounted. The power wire for the radar detector was pushed up through the hole, and the detector mounted on the bracket, which was painted to match the interior. It was pretty sweet, and kept you from having to mount the detector on the windshield. I wish that I had gotten pics of it, but like I said, this was many years ago.
Old Apr 26, 2003 | 06:49 PM
dsaint1347's Avatar
Since I run wires for a living I would rather run the wire all the way down to the fuse box with a spade connector at the wire.
Old Apr 28, 2003 | 05:35 AM
MartyMcFly's Avatar
Car: Z28
It's just like Alex Rodriguez - expensive, yes, but very effective. Car and Driver's test says it all. This thing has so much range, it's just unreal. Alot of money ($400), but man does it work.
I'll keep this post updated as to how it goes. I'll probably tear into it today or tomarrow. Thanks for all the reply's!
Old Apr 28, 2003 | 08:45 AM
transam305's Avatar
Car: 1989 White Trans-AM
Engine: 305 TPI hopefully Upgraded Soon.
Transmission: Crappy Needs Improvment.
i've got mine wired in to my cd player no problems what so ever it turns on when the cd player turns on or when the car turns on i mine if i shut the cd player off the thing doesn't turn off but you know what i mean. anyway no problems for me.
Frozer!!!
Jan 19, 2024 04:55 PM
kairles
Oct 26, 2015 09:13 PM
Ducati900ss
Sep 2, 2015 09:05 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
