How much does your box weigh?
Old May 14, 2003 | 01:34 PM
DonCamaro's Avatar
What do your guys' MDF and Fiberglass boxes weigh?
Old May 14, 2003 | 02:16 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
The typical well box is 50-55 lbs. The fiberglass stealth box I sell is 8 lbs. A fiberglass well box would probably be about 20 lbs.
Old May 14, 2003 | 03:43 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
My dual 12" boxes are around 60-70lbs, at least according to the UPS scales. I forget the exact weight... it's whatever the UPS maximum is, because I have to lie by a pound or 2 sometimes.
Old May 14, 2003 | 08:16 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
8 lbs
Old May 14, 2003 | 08:39 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
My box is MDF, and it is WAY too much weight! But, I'm not going to change it! My box is an oversized well box, and I figure it's about 60 or so pounds. I'm guessing the entire system at around 100 lbs.
Old May 16, 2003 | 01:57 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
I think I have most of you beat, although probably not in a good way. I bet my enclosure weighs between 80-100 pounds without the equipment. Maybe 130-140 with all the components installed. But the other figures posted sound about right. The well box that's in my brother's 89 probably ways about 50 lbs.
Old May 16, 2003 | 04:19 PM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
Around 120lbs, or so, but that was with her boots on. lol! :P
Old May 16, 2003 | 06:15 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
:sillylol:
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
