15's ?
Car: 91 Firebird
Engine: 305 TBI
15's ?
Would two 15's fit in the back of my Formula or will I not have room for my t-tops. Is any one running 15's if so please post a pic of them so I can get some idea of what I should do.
Guest
Posts: n/a
Re: 15's ?
I know that its not 15s but you couls get a couple E12As to put in. I have one and its more than loud enough for me and sounds great even in its little 1.2 cu ft box and only 800 watts. They also have 15s but i don't think you will be able to have 2 15s and you t tops. 2 12s and anywhere from 1000-2000 watts of of a good amp and I don't think you'll be disapointed.
Car: '88 GTA
Engine: TPI 350
Transmission: auto
with careful designing, you could get 2 15s and keep your ttops back there. problem is you wouldnt really have enough air space to feed those hungry beasts. you might be able to find some 15s that can live off of about 1 cu ft each, but it would probably be a better idea to save some money and get a good pair of 12s. they would probably sound pretty close to same and you wouldnt have to worry as much about space.
Car: 1985 Trans Am
Engine: upgrading...
Transmission: upgrading...
two 15's can definitely be done... but the ttops will be an issue.
beacause of the shier diameter of a 15 inch sub.. space is definitely an issue, but you will have no issues with 2 that you wouldn't have with 1. i can guarantee you this, because had i built the bottom of my sub-box to accomidate it, two 15's would have fit.
you DO have to note, however, that because of the size of the magnet on my particular sub, and the size of the cones on all 15" subs, it is VERY difficult (if not impossible) to mount a 15 flush with the top of the well.
raising the box up like I did will not provide you with enough room to accomidate t-tops.. not even close. that's not to say that you can't build such a box and store t-tops.. you'd just have to build the box appropriately and have some sort of rails that let your tops sit above the sub (& amp) without damaging anything.
the project actually doesn't seem that hard to me, the hardest part is building the sub-box correctly so that the magnet doesn't hit the angled-part of the well. i'll attach some pics so you can see what i did - i hope they help.
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
i have one 500 watt pioneer premir IMP 12'' sub in my jeep running off a 180 watt kennwood crap amp, (selling amp with jeep keeping sub for firebird, buying bigger amp) and the thing will kick your ***, it has more sound then i will ever need. why in the blue hell would you need two 15''s ? competition, trying to go def?
oh hey i think i just remembered. whoever blows there windows out first wins!!!
Car: 91 Firebird
Engine: 305 TBI
Actually its because I feel sorry for all those people that cant afford a nice system, so I thought if it was loud enough I could share with the poor saps.
Car: '88 GTA
Engine: TPI 350
Transmission: auto
oh, and im also getting these subs to blow away those guys that pull up next to you at the light with their radios blaring with all the statics and distortion. boy i hate those guys. ya'll know what im talking about.
Axle/Gears: n/a
Originally posted by tamu130
i see your type periodically. you think what you have is impressive and it may be to you just like a mustang owner is with their cars. you enjoy what you have and we will enjoy what we have.
i definatly see your point on the mustang thing. keep doing your thing. Originally posted by tamu130
i
oh, and im also getting these subs to blow away those guys that pull up next to you at the light with their radios blaring with all the statics and distortion. boy i hate those guys. ya'll know what im talking about. .
i
also on a simalar note, just to clearify, i don't dislike systems with alot of base, my seystem in my old car had som decent base. what i don't like is a system that is ALL base, (the guys ou are talking about at the lights, allyou hear is a little thump and no clear sound.) as long as the rest of your system stands up to your subs i say the more power to ya!!!
also, while i have the attention of the experts here, what is the advantage of having say two subs as opposed to one ?
Car: 91 Firebird
Engine: 305 TBI
also, while i have the attention of the experts here, what is the advantage of having say two subs as opposed to one ? [/B]
To me its louder and hits harder.
Car: 00 TA, 91 Formula, 89 RS
.... however, one cannot simply say "two subs hit harder than one". There are some good single subs out there that will hit better and louder than 3 lesser subs.
I think that the effect is obvious though, when you have a single sub and you add a second sub of the same type... it's that much more bass... assuming a proper job on the installation and that you have the required amplifier power and enclosure space for the additional sub.
Car: '88 GTA
Engine: TPI 350
Transmission: auto
hey man sorry if i offended you.
i definatly see your point on the mustang thing. keep doing your thing.oh and i agree, if you got some bass, back it up with some treble and mids. loud is one thing, annoying is another.
two subs are better than one if you want it louder, plus they can be better sound quality wise. if you have them wired in stereo, you can get both sides of sound stage working seperately yet together. in mono, the subs kinda take bass from each side and take the middle ground so to speak.
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
Re: 15's ?
Simular setup to Chris's 85z. We had the amp mounted in the glove box to be out of the way. Looked clean and sounded good.
I have one 500 watt pioneer premir IMP 12'' sub in my jeep running off a 180 watt kennwood crap amp, """"and the thing will kick your ***"""", it has more sound then i will ever need. why in the blue hell would you need two 15''s ?
Re: Re: 15's ?
Originally posted by Hawk92z-TDZ
We put 2 MTX 15"s in our old 84 Camaro. Lots of room for the T's.
U will want to put covers on the Subs so your T's dont rest on the speakers. The ones the JLw3 sub's use work great. And mount the amp in the glove box again so the T's dont sit on it.
Car: 1989 Pontiac Firebird Formula 350
I have 15's in one of my car. I thought I would just post a pic of what it looks like. This is not inside of a firebird or a camaro this is inside of a dodge daytona. I like it and it was built for competition and also everyday driving. My hearing is just fine. I never really cranked it up when i was driving in my car. I could turn it up and keep the bass down and it sounded awesome. Then when I took it to competition we used a podeum and the loudest I hit was 154.1 DB. Just thougt I would share. I am planning on putting 2 15's in the back of my firebird in a custom fiberglass box that I am going to try and build myself. When i start I will post pics of the progress
I know this a 3rd gen website but I thought I would share
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I'm in the process of building 4 15"s into the back of my Iroc... just like the pic I attached... that was my 1991 GT... don't kill me! It was before I realized Ford sucked really really bad.
