New Deck/Oops
Old Jun 15, 2003 | 02:22 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
New Deck/Oops
When installing a new deck and forgetting to unplug the negative, what exactly would that blow? My car wont start, and the starter doesnt click... I dont know if it was that it might have been... if it was what else could I have blown?
Old Jun 15, 2003 | 05:35 PM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
check all the fuses. replace any that are blown. that is probably your problem. try that and get back to us.
Old Jun 15, 2003 | 05:37 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
The fuses are all good... The ignition wire to the starter isnt giving any power at all... he hot jumped the starter so I know thats good... but I dont know what could have caused that ignition wire to the starter to go... its not in any contact with the ignition wire to the deck is it?
Old Jun 15, 2003 | 05:40 PM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
if thats not it, then i dont know. i would suggest though that this be moved to the electrical board. they may be of more help then the audio board. good luck.
Old Jun 15, 2003 | 05:52 PM
zfever's Avatar
could be your starter solenoid. but yea, the electrical board would be of better imput.
Old Jun 15, 2003 | 08:05 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
ahhh sounds stupid.. but.... did you try removing stereo to see if it will start? and you don't have any gadgets like a car starter or something that may be killing the power?
Old Jun 15, 2003 | 08:08 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Yeah I took the deck out and everything... I am convinced now that it has to be some sort of coincedence... I have this problem posted in another part of the boards too...
Old Jun 16, 2003 | 06:59 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
well only thing to do know is to get a service manual and meter all the wires needed to start the car.. see what has 12volt all the time.. see what has it when key on, and when on start... anything that says it should have power but doesn't.. theres your wire... but boy that ain't gonna be fun..
Old Jun 16, 2003 | 08:34 AM
napalmdemos's Avatar
Car: 91 Firebird
Engine: 305 TBI
Did you try disconecting the battery for a couple of minutes then hooking it back up?
This should reset the computer just in case it has some kind of auto protect.
Old Jun 17, 2003 | 03:56 PM
Tyler-88's Avatar
no power on ignition = blown fusable links
