Weird Problem
Old Jul 4, 2003 | 05:04 PM
iroc4ever's Avatar
Car: 1989 Iroc-Z
Axle/Gears: 2.73 (for now)
Weird Problem
I just installed my new Pioneer head unit today and it being my first time doing this i wasnt sure if i was doing it right. After I was done I noticed that I must have done something right cause i was hearing music. Now the problem is I only hear music when the plastic connector with all the wires is only pushed in halfway to the head unit. When its pushed in all the way,there's power to the unit, but no sound...
Any thoughts to something I might have done wrong or should double check??
Old Jul 6, 2003 | 05:41 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
once the conecter is all the way in are you pulling anny wires t otightly, if so they may not be all the way connected. also, if your decl is used you may want to try cleaning the contacts with a pencil eraser or alcohol/qtip. used units often have a thin layer of dirt on contacts, my dad was about to throw away his old kenwood cause it would not work anymore, i cleaned the contacts on faceplate, good as new.
hope this helps
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
