Monster Wire!!!!!!
Old Jul 11, 2003 | 04:00 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
Monster Wire!!!!!!
ok, i have a little puny amp (70 watts, smaller in size then my deck ) i am running thick guage moster wire to it so if i upgrade my amp i do not need t re-run cable. where do i run the wire through the firewall. i have never done this before so please be specific. also if somone hapens to have pics hat would be cool.
Old Jul 11, 2003 | 04:04 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Well, look under the dash on the firewall where the steering column goes through, there should be sound deadening around it. That's where I routed my 0/1...
Old Jul 11, 2003 | 04:06 PM
Xophertony's Avatar
Axle/Gears: n/a
cool, i am gonna go look at that right now,
btw if anyone else has done annything different please fill me in, i would like to have options
Old Jul 11, 2003 | 04:30 PM
kewl_blades's Avatar
Car: 2x1991 & 2000 Camaros
Engine: 350, 305 & LS1
Transmission: TH-700R4 and 4l60E
I (carefully) drilled a hole behind the passenger kick panel and put in a rubber gromit (so that the metal wouldn't rub). Then routed the cable thru the passenger fender. It was the shortest past to the amps in the rear trunk.
Old Jul 11, 2003 | 04:44 PM
Xophertony's Avatar
Axle/Gears: n/a
thankyou, although that sounds like a great way, i am trying to avoid drilling. to scared i would **** somthing up real bad.
Old Jul 11, 2003 | 04:45 PM
87GTA Runner's Avatar
Car: 87 GTA
On my 87 there was a hole about the size of a 50 cent piece above and to the right of the steering column where it passes through the firewall. It is about 2 inches above and right of the steering column. It has a large rubber plug in it already, so I made a hole in it and used the same plug for the wire grommet. I just pushed the power wire through until I saw it pop out from behind the padding that is under the dash. A great and easy place to run the wire.
Old Jul 11, 2003 | 04:49 PM
Xophertony's Avatar
Axle/Gears: n/a
sweet, thats the one i am looking for, the near effortless, seems like it was ment to be wire hole, you my man are awsome!!!:hail:
::: dances around room ::::
Old Jul 11, 2003 | 04:54 PM
Car: 87 GTA
That's what I thought, too. The firebird gods put that hole there for us. It wouldn't really work for Camaros, though, you know, the battery on the opposite side.
Old Jul 11, 2003 | 07:43 PM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
I drilled a hole in the firewall and sealed it with a rubber grommet.
Old Jul 11, 2003 | 09:44 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
If you don't have power equipment (like locks and windows) then there will just be a plastic filler where the hole is. I took that out, cut a hole in it, and ran the wire through there. That way you have the convience of going through the kick panel without the drilling.
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
MY87LT
Aug 17, 2015 08:43 AM
86White_T/A305
Aug 17, 2015 12:16 AM
