IN Dash ps2
Old Aug 15, 2003 | 09:54 AM
89RS-T's Avatar
IN Dash ps2
Ok i have a 89 rs camaro. i am in the prosees of putting in my ps2 and getting rid ot the old ps. i want to put in the top right corner right next to the vents and as close to the top as possible!! First problem.... Ac vent well i mnade a new duct for that. no the rea; problem i need two more inches!!!! what is dehind the firewall two inches i need it to be open and it cqant be wett!!!! can i cut that will it mess anything up?? and will it get wett??
Old Aug 19, 2003 | 10:54 PM
steves86TA's Avatar
Car: 2008 silverado
Engine: 5.3
i cant understand one word of what you're saying
Old Aug 19, 2003 | 11:01 PM
IEatRice4dinner's Avatar
Car: IROC-Z
Engine: L98 350/ 5.7L
i think you would be in the engine campartment if u cut through the firewall.
Old Aug 20, 2003 | 12:23 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
please type more clearly, those of us not born and bread using aim and chat rooms are having dificulty following you, from what i have figured you need to go back toward your engine two more inches. i would say relocate the ps2 in the rear seat. and run controller cords up front, would make more sense and nobodey would see it so they can not steal it. if you are atill set on putting it there then you may just have to deal with it sticking out like that. but if you stick it real lose to the dash pad you may not even notice, thats what i would do.
oh and by the way!
Old Aug 20, 2003 | 07:48 AM
outragis's Avatar
I know what you are asking! the air ducking is between the firewall and dash!you should be able to cut in there, and heat the ducking with a heat gun!
Old Aug 20, 2003 | 03:32 PM
89RS-T's Avatar
I DID IT
ok yeah outragis that was part of the problem. but i solved that.. I cut the ac pipe off and bought some flex hose and rerouted it to the passanger vents. The problkem was there is a support behind all the padding. i didnt wanna cut it do to lack of support as it is (ttops) so all i had to do was drill two holes one for each wire and then one for the fan. ! it loks awesome i will get some pictures soon so u guys can see what i did!! Waht a pita!!! BUt iut was well worth it!!!
Old Aug 24, 2003 | 05:45 PM
Cuno's Avatar
when are the pics coming? I am considering tossing a PS2 into my Camaro..want to see what your set-up looks like
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
