Wierd CD player Problem
Old Sep 3, 2003 | 09:27 PM
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
2 actually.... First one that happened, I tried to turn my defrost on, and the cold hot slider as it goes towards hot, starts pushing the cd player out. Its bolted in, so it only bugs out, but it will only go about half way. How can I reinstall it to fix it? 2nd: It happened a few days ago, fixed itself, and happened again today... All 4 speakers cut out at the same time, and i have subs, so i have ONLY subs, nothin else... I went outta town for laborday, came back without doin anything to it and they worked, then cut out today. Would I have to add another amp if the CD player is shortin out?
Old Sep 4, 2003 | 07:53 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
One of your speaker wires is probably going to ground. This will damage the HU. Check and fix your install.
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
