Question: 10's and sub box
Old Sep 9, 2003 | 07:43 PM
91RSmaro's Avatar
Ok, I have a question for anyone who is running 10s in their hatch area. I am making a box for back there, but the problem is a 10 inch sub will hit the best with a perfect 12x12x12 cube (So I have been told). Although that does not fit in the area behind the wheel well. I was curious was others have done to occupy the 10 inch sub. Or what people suggest to do in order to get good sound, without making acess to the tail lights too difficult (Incase a light bulb goes out). Any help would be great, thanks.
91RSmaro,
Steve
Old Sep 10, 2003 | 06:35 AM
napalmdemos's Avatar
Car: 91 Firebird
Engine: 305 TBI
This is the box setup I run my one 10inch in. Its angled at the front so I turned it upside down and it fits into the well.
Attached Thumbnails Question:  10's and sub box-pioneer400wimpp.jpg
Old Sep 10, 2003 | 07:30 AM
9177's Avatar
angles and and lengths of side aren't going to matter as long as the volume is correct assuming its sealed.
Old Sep 22, 2003 | 03:23 PM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
http://www.subthump.com/acamaro3rdgen.htm
go there get ideas
demensions dont mater
just try to have the rquired volume(cubic feet usually) of the speaker you want to use.
most of all be creative.
good luck and have fun with it man
Old Sep 24, 2003 | 10:40 AM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
Go to the manufacturer's websight and see what they recommend for space, and build the box as close to that as you can. All speakers have different space requirements.
Old Sep 24, 2003 | 02:20 PM
firedawg225's Avatar
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
here is my box 2 Kicker solobaric L7 the space required for 2 sealed is at least 2.0 cu.in i'm running 2.4 flattens out the curve. here's my pic and you can remove the box if you need to do any work.
Nick
Attached Thumbnails Question:  10's and sub box-stereo2.jpg
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
